Step 5Step 5: Attaching the support bolt to the mounting plate
Tighten the support screw to the mending plate with another nut and tighten the two bolts until the mending plate can't spin around the screw without a very solid push.
The support screw is what will prevent the whole mount from swinging around every time you nudge the camera, so you want the grip to be fairly tight. Now is a convenient time to tighten the joint but you can always go back and tighten it later if the mount proves too loose.
Add Comment
