RGB LED CUBE 8x8x8 With Animation Creator
Introduction: RGB LED CUBE 8x8x8 With Animation Creator
New Version Here
Facebook Page
Draw 3D Animation with software!
Include acrylic case, tinted copper wire 0.6mm width
Audio Spectrum Mode and Night Light Mode
Include Remote Controller
Step 1: Soldering the LED
We will start from the LED, with the help of soldering frame and a sort instruction
***use 30w/40w solder iron
A. Bend the led leg beside anode(+) (the longest one) and hold all led on the frame
B. Solder each led leg with tinted copper wire, first is the red green blue pin, when we have 8 led sticks we can solder the anode pin with copper wire in horizontal way. The 3D printed holder can help spacing and alignment.
C. Finally cut all the extra pin/wire, and remove the PCB frame / 3D printed holder for the next layer of led. The anode leg vertically to the PCB ground will be soldered when assembly to the PCB driver board.
D. The 3D printed frame/holder can use for spacing alignment when assembly all led stick.
Practice make perfect, take few wires and leds to try soldering and test you tools/skills first.
Tinted copper wire has been straightened in the kit.
Here is a video for reference(using pcb frame) (will upload video for 3D print frame later):
Step 2: Sketch Up the New Holder for Soldering Leds
1. Cut and bend the led legs, test if the position is correct on the holder,
2. 3D printed holder need some clean up for the detail, can shape with knife or melt with high temp heat.
3. Stick the holder with double side tape on a flat surface, better hold on a 45 degree angle, so the leds won't fall out.
4. Solder the leds with copper wire, after the first 4 row, move upward to solder the 5th and 6th, than 7th and 8th row separately.
Step 3: Correction of the Holder for Soldering Horizontal Anode Wire.
There is a important correction on using the led holder, you should double check if the orientation of the PCB and LEDs is correctly look like the final finish product.
The holder in the picture has a purpose for holding the led stick and solder the horizontal anode wire, but the gap was reversed, so it have to rework the hole a little larger with a 5mm screw driver, and use it like the picture show.
Step 4: Soldering the PCB
Parts included in the package may be slightly different, but all you need for build the LED Cube is included;
PCB 4.0 (4.1) Notice!!!!!!
  • Main Controller Board already soldered
  • You Only need to solder DC jack and 30 similar SMD parts, which takes less than 60 min to do it.
  • Other parts on the cube board are not in use and should keep it clear, otherwise the circuit may shorted.
  • If you are new to solder smd parts, buy some good quality solder wire and solder flux will help.
  • You may add a 2 pin capacitor to each IC 126D, on the VCC and GND PIN to protect it.
Reference Video / Technique demo / Also search youtube for solder paste with hot air.
Step 5: Combine the PCB and Led Vertical Layer
Start to solder led vertical layer to PCB, you are close to finish the assembly.
You should test the led vertical layer with multimeter short circuit test, and problem will be fixed easily before all cube column soldered, most cheap multimeter has enough current to light up the led, some may not.
Stop soldering onto PCB if the animation does not look correct.
Each horizontal anode copper wire need to connect a wire down to PCB, and you can use 2 different way to connect all anode wire to the PCB as the image show.
Finally you can solder one or more copper wire on the top of the cube, connect each vertical layer's anode wire, this help space alignment
Step 6: The Acrylic Case
If you buy the acrylic case, it look like this above, you can make your own even with glass. These are cheap good but heavy to shipment cost, and cost on laser cutting.
Tools needed is acrylic glue / acrylic cement same as the video used. Should use plastic tape to hold all side together, then apply the glue from inside. The cover sheet on the acrylic can remove partly for apply the plastic tape.
Watch this video for reference
*Make sure no air bubble on the plastic tape applied, some cheap plastic tape make dirt on the board.
Step 7: Firmware Upload and Aninmation Upload
For customer who don't know programming, they just need to upload firmware which was a .hex file to the LED Cube. Which means they can play the cube like a mp3 player, upload mp3 file and it can play.
Drawing Software can share file to other user
Upload the .hex file (firmware):
1.Install the CH341SE driver for windows first.
2.Open STM ISP MCUISP software, press button "..." to locate the .hex file (firmware file)
3.Connect the usb programmer works as USB device, connect to USART. GND to GND 3.3v to 3.3v RX to TX, TX to RX.
4. then press "start ISP", and works done.
setting on the Remote Controller
0 ------------ Animation from the drawing software
1 ------------ Music spectrum mode
2 ------------ Animation from the firmware
3 ------------ Night Light Mode
4-9 --------- adjust color of the Night Light Mode
C------------ Snake game
Step 8: Firmware, Schematic, Source Code and Video Demo
The firmware can be upload with mcuisp.exe, no need to learn about programming. The source code is for hacker use only.
Step 9: The Animation Drawing Software, Fast and Easy!!!
New Animation may found here https://drive.google.com/open?id=0B3w2uIW46VgQflFq...
Its Now fully translated to English https://drive.google.com/open?id=0B3w2uIW46VgQQlR2...
Remember to save the cube8.exe with animation file in same folder
Alt + right click = Pick color
Shift + Mouse Over = Erase
Crtl + Mouse Over = Fill Color
Right Click = Fill Color
Step 10: Tips for Building the LED Cube - Must Read!!
1. Make sure you read the PCB soldering guide before you start the soldering. Some smd electronics have to solder according to the positive/negative pin.
2. The leds may have error after soldering heat, test with night light mode on the cube board, and fix it, do not solder more led before the problem fixed, otherwise you may need remove all parts and start from 0 to check where the error / problems come from
3. Prefer power supply is 5V5A, 5.5x2.1mm DC connector,
4. You should learn about PCB markings and smd parts markings, this help you read this instruction.
Step 11: Additional Info
Change usb serial Port COM number in windows
BPS for upload firmware suggest 115200
BPS for upload Animation suggest 460800
Here is the Cube8 firmware code for hacker sharing the basic code to run the cube only. It need the Keil software to open it.
Step 12: Customer's Work
Looks like no different, because using same kit and solder with PCB frame holder.
This pro customer make the color controller with Griffin Controller
There is a new firmware created by Brant James
Very cool animations and custom functions https://www.instagram.com/rgb_led_cube_for_sale/ I had capture a few video on the latest instagram post, and here is the download https://drive.google.com/open?id=0B3w2uIW46VgQZTNR...
The remote keys :
- + Increase brightness
- Decrease brightness Play
- Pause or Resume FFW
- Next Graphic RWD
- Previous Graphic Power
- On/Off
Step 13: Data for Old PCB 3.0 Customer
Just download the file here it contains all different sources for pcb 3.0 only
6 People Made This Project!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Science of Cooking
    Science of Cooking
So,we are doing a project like this for college,but with single color LEDs,there is any way that we can use this program in the dame way you did?
It only work with the program and the hardware in that cube.
I have almost finished the cube but I have a problem. After installing the driver to my laptop, it still does not recognise the microcontroller. Any ideas?
Hi, did you connect it with a usb to ttl programmer?
I think I've found a short between three leads on the PCB. I had soldered the component a second time after the first wasn't so successful and saw a lot of erratic behavior. After desoldering, I verified with my multimeter that 2, 3, and 4 are showing continuity despite there being no discernible connection on top of the board. Does anyone have any experience with this? Is this something that can be fixed? Any help would be greatly appreciated!
For that matter, it sounds as though this should be working as I solder in the rows of LEDs one by one or is that not the case, do they need to all be connected for this to work correctly? I have two in at the moment and am seeing that current is flowing through only about half of the resistors on the board.
They can work with vertical layer one by one, make sure the anode pin is connected to the pcb board. Crrently there will no animation if that 3 pin still sorted.
Hi, that three pin connected to twenty 126d ics, so they can be sorted on either one of the 126d ics, you can refer to the schematic, all 126d ICs has 3 signal pin connected to the 245(exactly the three you circled). You may need some flux to clean up the solder.
I want to purchase this kit, but I don't want to use the built in controller. Your programming is very, very good. It is much better than mine, but I wish to drive the cube with my own hardware just to challenge myself. I have an FPGA that I'm going to use to offload multiplexing from my microcontroller. Is the mainboard only 2 layers? If it is, it should be easy for me to modify the board to drive R, G, and B channels independently. Would you be willing to share the PCB file so I can get an idea of what modifications I'd need to make before I purchase the kit?
Hi, I am reselling this item from a supplier, so I don't get the pcb file. But the schematic file is shared on step 6, it was correctly rotue same as the pcb board. But I extend the main controller parts out to the small stm32 controller board. I think you idea should work if you have the ic data sheet.
