3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Astronomer's red light (Maglite mod)
Astronomer\
I've taken some interest into amateur Astronomy recently and came to realize that, as a hobby, it can get very expensive very very fast. The amount of equipment available at any price range is tremendous and just getting started can mean dishing out some serious money. Learning as much as I could before deciding what kind of equipment to purchase I found astronomers use very dim, red colored flashlights as to allow for their eyesight to remain as adopted to night-time vision as possible. Since every penny worth saving on other equipment equals more aperture for your scope I decided to make a very simple red filter for my, already partly modded (with LED) Maglite.
Time required for this project: 1 hour
Cost: $0 (I had everything on stock a.k.a. rubbish laying around)
Step 1What you'll need
What you\
To make this you will require at least:
- MAG LITE MINI with an LED instead of the regular light-bulb.,
- A thin layer of acrylic foil. I got mine from a broken ATX power supply. Should be about 0.5mm thick,
- Dark red nail polish... preferably the one your spouse does not like too much,
- Thin magic marker,
- Scissors,
- Fine grain sandpaper
Additionally, I ended up using some duct tape, nail polish thinner and a pair of equally sized plates of glass to press the two chips together.
I would recommend against making this mod with a classic MAGLITE light-bulb installed, as I remember it heating quite a lot as opposed to a bright LED. Than again if you should want do, you could simply change the light-bulb with an already colored red LED and go about it that way.
12 comments
Aug 8, 2010. 12:45 AMimkwl12345 says:
perfefct fo trying to hide in the dark while playing lazer tag :D
Jul 6, 2009. 3:05 PMlemonie says:
It obviously works, but looks a bit opaque. Had you considered something more translucent like this?
http://www.shopwiki.co.uk/Jewellery+Making+%3A+Dip+Film
L
Jul 9, 2009. 12:48 AMLftndbt says:
You want it opaque. Any brighter and you will have ppl throwing rocks at you in the dark... Astronomers don't like bright lights, trust me.
Jul 9, 2009. 12:43 PMlemonie says:
Dimmer bulb then. Or a red LED... L
Jul 9, 2009. 12:51 AMLftndbt says:
I love astronomy. Do any astrophotography? This is my best effort so far, only got my scope 2 weeks ago. This is taken with a 4yr old sony cybershot... Nice I'ble!! I need to mod two torches tonight, thanks.
Jul 9, 2009. 4:40 AMLftndbt says:
"they've located a defect upon inspection, hence delivery will be somewhat delayed." Oh you are mistaken my friend, that is by far some of the best news you could here... Believe me you would be cursing if they didn't pick it up and sent it out like that. This was shot with a budget 70mm x 900mm refractor.
Jul 7, 2009. 8:03 AMsnorkledorf says:
I've done this in the past with lithographic tape (red). It's just like red Scotch tape, made for the printing industry. It comes in several widths. I used the 1 inch and put it on the inside of the factory lens. One roll (60 ft) will do many flashlights.
Jul 6, 2009. 6:14 PMloximuthal says:
I went even simpler: nail polish straight onto the lens of a handy flashlight. All done! I'll bet this one works even better than mine, but I was feeling lazy.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:vincenc
