For certain applications a red lensed flashlight can come in very useful. If you are looking at star charts or trying to get around the woods and want to not ruin your night vision, these are perfect.
This instructable makes one from parts you can find very easily and cheaply.
Step 1: Supplies
For this instructable you will need:
1. LED flashlight, the one i used is from a walgreens, you can get these lights for much less on ebay, about 99 cents.
2. Red Photography Gel, This was free from a photo store down the street they give away sample packs to students.
Step 2: Take Apart Your Flashlight
First you want to take apart your flash light, do this carefully, not all these lights are made to be disassembled.
Step 3: Cut The Gel
Cut the gel into a square that will fit into your lens. Then use the clear plastic from the flashlight to cut a circle the size of your lens.
Step 4: Rebuild Flashlight
Step 5: Results
Once the light is done go test it out, you should be able to see things and still have your night vision when the light turns off. If it seems too bright, you may need a deeper red.
This flashlight will be very useful on your next camping trip!
curious youth says: Jun 25, 2012. 3:03 AM
i did this. except i couldnt get the photography gels so i used the plastic battery separator thingy that came with the flashlight. glad it was red haha
luvit says: Aug 2, 2010. 5:39 PM
this helps me run from the cops. works every time.
Landon Sullivan in reply to luvitSep 17, 2010. 4:55 PM
+1
thepaul1993 in reply to luvitAug 3, 2010. 5:28 AM
How will this help you run from the cops?
ryanninjasheep in reply to luvitAug 2, 2010. 8:38 PM
sure... sure.
frenzy (author) in reply to luvitAug 2, 2010. 8:18 PM
LIKE
MACKattacksnipe says: Aug 14, 2010. 4:51 PM
i got 2 of these at Harbor Feight for 2.99 *(with coupon)
pdc4770 says: Aug 7, 2010. 10:09 AM
With white LEDs the light is turned pink rather than red. That means less protection for night vision. A torch fitted with one of the old incandescent bulbs is better. In Britain, look for Quality Street sweets (I think Americans call them candies?) with red cellophane wrappers that are perfect. Good excuse to eat sweets too.
onrust says: Aug 4, 2010. 7:38 AM
Great post. More people should use these.
plugable says: Aug 4, 2010. 4:42 AM
Very useful, I have though this project might be more expensive. Thanks for the info!
solarblade90 says: Aug 3, 2010. 12:12 PM
This is great! I've been looking everywhere for something like this.
Sephiros says: Aug 2, 2010. 6:23 PM
And why, pray tell, would you need such a thing in a bathroom?
KellyTheAlien in reply to SephirosAug 2, 2010. 6:58 PM
To aim. :D
Sephiros in reply to KellyTheAlienAug 2, 2010. 7:19 PM
I'd imagine that, unless you're a ninja, you'd pee with the lights on. Of course, if you're a ninja, you could see in the dark, and you certainly wouldn't need this instructable.
DELETED_madscientist167 in reply to SephirosAug 3, 2010. 9:20 AM
(removed by author or community request)
Sephiros in reply to DELETED_madscientist167Aug 3, 2010. 10:11 AM
If you were a ninja, you wouldn't have told me, or else I'd already be dead.
stephenniall says: Aug 2, 2010. 5:11 PM
I need one of these I never thought of this .. I thought of buying a flashlight and replacing the LED with red LEDS .. THis is easier and cheaper . Thanks :D
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
