Using fabric paint, freezer paper, and some ninja xacto skills, you can make your own handmade screenprinted clothes!
Step 1: The supplies
For this project you’ll need something to screen print on, like a shirt or sweater, some fabric paint, an iron, freezer paper, a paintbrush, a design, and a really sharp xacto blade. Don't forget the sharp part...
Step 2: The image
Take your image (which should be stark black and white) and place it print side down on the shiny side of your freezer paper. Tape it in place. When you flip it over, it should be visible through the freezer paper on the other side.
Step 3: The cutting...
This part takes the longest. Begin carefully cutting out your design from your freezer paper. Keep an eye on "floating" pieces, like this one, and put them aside somewhere safe.  Number really tiny pieces if you're worried you won't be able to put them back where they were without help.
Step 4: The finished stencil
This is how it should look all cut out. Trust me, this takes a little while...
Step 5: Extra detailing
If you want to add extra detailing, like in my case, sailor stripes, you can use simple things like tape or store bought stencils to add fun effects. I used tape and spray fabric paint to achieve this...
Step 6: Ironing
Now it's time to secure the stencil.
Carefully place the freezer paper stencil on top of your hoodie or shirt, wax side down. Once you’re happy with your placement, take a hot iron and press it directly on top of your design. Don’t move it back and forth, like you would if you were really ironing something, just “stamp” it over all areas of your design, pressing a few seconds at a time, until it’s all pressed flat.
With the wonders of freezer paper, the wax side will bond securely to your shirt, but when removed, will leave no residue.
Step 7: Painting
Spray a generous coating of your fabric paint over your design, covering all the open spaces. I used a piece of extra paper I had around to help mask the spray from the edges. If you don't have spray on paint, don't worry. All you want to do here is dab on the paint. DONT BRUSH! You might lift up delicate edges. Just dab the paint till the whole thing is covered...
Step 8: Pulling off the stencil
Verrry carefully remove your stencil, taking care not to let any excess paint mess up your crisp image. Use your knife to remove really tiny, delicate pieces. Let the paint dry, and follow your paint's instructions for setting it...
Step 9: Finished!
Your hoodie, shirt, whatever, is done! No one would guess you made it yourself with at-home materials. Want a more detailed tutorial, as well as image ideas? Check out the full tute here. Enjoy your new screen printing skills!
hm_fashionluva says: Nov 30, 2012. 8:30 AM
THanks for this. I've looked at several tutorials and your seems the most do-able and inexpensive.
AluraDankk says: Jun 27, 2012. 5:23 PM
Question: Do you have to take off the design immediately after you paint, or can you wait til it dries? I'm such a klutz I'd be afraid of touching it after i was done..
Infra_red says: Jun 3, 2012. 7:49 PM
This is by far the easiest tutorial I have seen on the net so far. Thanks, I will be trying this very soon.
eallan says: Apr 2, 2012. 12:17 PM
Awesome! I've been looking for a way to do screen printing inexpensively but still come out with good quality. I was thinking about stenciling but didn't know how I should have approached it. Going to give this a try.
Question though: have you been able to reuse the stencil after the first use? Or is it a one time use thing because of how the freezer paper wax works with it?
Miscelinious says: Jul 25, 2011. 12:09 AM
Process worked out great for me. Freezer paper gives a really sharp and clean edge. :)
TehGoatLord says: Jan 16, 2011. 4:07 PM
Are there any alternatives to Freezer Paper?
rasterweb says: Jan 3, 2011. 6:10 AM
While not actually screen printing, you could use this freezer paper stencil idea in conjunction with screen printing... which is cool. :)
Wicken says: Jan 2, 2011. 11:20 AM
This is beautiful, I needed an 'Ible like this for a project I wanted to work on. Thanks!
l8nite says: Dec 30, 2010. 8:53 PM
I believe the spray bottles of fabric paint are available at the large craft stores.. Nicely done "ible" with some great pics
Ngendrer says: May 29, 2010. 8:53 PM
hey a like it a lot!!! thanks
anotherway says: Apr 13, 2010. 6:10 PM
cool! i've used a brush to stipple paint onto a shirt before, but i like the idea of using spray fabric paint! looks easier and faster. where did you get your spray fabric paint?
siedpe13 says: Mar 9, 2010. 7:14 PM
i believe this proccess is just called stenciling
UrbanThreads (author) in reply to siedpe13Mar 9, 2010. 9:35 PM
Yeah, when I said this was "at home" screenprinting, I don't mean you're doing it literally. I just mean you can achieve the same effects at home, with household materials.
Jyssa says: Mar 7, 2010. 11:47 AM
How Extremely FunkyDO! Yes, I would also say not technically screenprinting (there's no screen) but I think I actually like it even MORE than screenprinting! Aside from the non-duplicability...but what a stunning one-off you've made! :)
Sincere kudos to thee, o talented one. :)
And spectacular design choices! :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
