Step 1: Getting Started
What you will need:
- Black and white image (printed or drawn)
- The t-shirt (can also be used on a bag, pants, whatever your heart desires)
- Fabric screen printing ink (I used a brand called speedball. Highly recommended and not a mission to find. Available at fabric and craft stores)
- A thick glue (mod podge is my favourite and is cheap and available everywhere)
- Embroidery hoop ($2.05 at Fabricland)
- A sheer material (I used an old pair of nylons that had a run in them)
- Pencil
- Paintbrushes (various sized depending on how detailed your image is).
Step 2: Finding an image
Remember that you are going to be tracing this image down the line, so if it is your first time doing this, you may want to chose an image with less detail.
Open it in Photoshop/MS Paint and convert the file to a black and white image.
When you've drained the photo of any colour, print it out and let's get started.
Step 3: The fun never stops
Once you have completed said task, take the image you have printed out (or drawn if you have a steady hand). Place the embroidery hoop face down against the image, so that the fabric is directly against your drawing, and using a pencil, gently trace the image onto your fabric. Remember, gently tracing is vital. I have known from experience that if you are using old nylons, the fabric can rip very easily.
When you are done tracing, even though you traced GENTLY, you should still be able to see a clear outline of the image you are drawing.
Step 4: Before you start painting on your t-shirt
Again, fill in the areas that you do not want to appear on your t-shirt. See images to better understand.
Start with the areas closest to where you want the black ink to appear (image 1) and work your way out until you have enough of a border so as not to have paint drip into areas where you do not want to paint (image 2).
Step 5: Painting onto your shirt
When you feel that you are done, slowly peel off the embroidery hoop so as not to smudge the image you've just pained.
At this point, refer to the ink paint you are using in order to determine how long you must wait for it to dry. Waiting times vary from ink to ink.
Step 6: GOOD AND DONE
Put it on when you go out and show off how good of quality a t-shirt can be, even when not using expensive silk screening machines.
Visit Our Store »
Go Pro Today »
I did this based on the earlier version. For an image I took a picture and created a black and white image. Getting that right was the hardest part of the project, and it still came out wrong. Have patience and step back from the final image to make sure there are no problems. I tinted my Mod Podge with food coloring so I could see it. My table top was white and white Mod Podge was just too hard to see. I used inexpensive acrylic house paint (custom color from Home Depot) instead of the expensive Speedball paints. Acrylic house paint Never comes off a shirt. For a sheer material I got some cheap, not stretchy, lace at Wal-Mart. It was reasonably sturdy to transfer the design. To spread the paint quickly and evenly across the stencil I dumped a load of paint and spread it with an old credit card. As I recall all these hints came from Threadbanger's Instructable and the comments.
You can reuse the stencil if you clean the paint out quickly. You can make several prints at one time, but the paint (or ink) will start to dry and fill the holes, so keep the process moving and be ready with a hose to blow the paint out as soon as you are finished. If the paint dries, it is permanent. For that matter, you could probably use acrylic paint instead of Mod Podge to create the original stencil.
