Introduction: Atari Joystick Jewelry Box
Keep your jewelry or random trinkets in style* with this Atari box!
*Disclaimer: May only be considered stylish by a small, but fantastic, subpopulaton. Space invader not included.
Step 1: Materials and Preparation
Materials
Shellac
Paper
Sandpaper
Wood glue
Wood
1/4" Walnut (Box top and sides)
- 1 piece - 3 1/2" by 4"
- 1 piece - 3" by 3 1/2"
- 4 pieces - 3 1/2" by 1 3/4" by - Cut with mitre saw
- 3 1/2" by 4"
- 3 1/8" by 3 1/2"
- 1/4" piece
- 3 1/2" long
Cherry veneer (Top markings)
Tools
Mitre Saw
Chisel
Brush
Hole saw
Drill
Clamps
Scissors
Step 2: Chisel Box Sides
Cut sides so that the top will slightly overlap the bottom section of the box.
- Cut each of the 4 side pieces in half
- Cut 1/8' of length from the bottom four pieces
- Chisel out 1/4" from the inside of top 4 pieces
- Chisel out 3/8" from outside side of the 4 bottom pieces
Step 3: Stick and Button
Purple heartwood adds a bit of color without the need for paint or stain.
- Sand the 1/4" disc cut from the dowel. This will be the joystick button.
- To replicate the hexagonal shape of the stick, put 3 1/2" dowel in vise and chisel down to have six even sides.
Step 4: Center
Center piece
- Cut out a circle 3" in diameter and tab to create the shape on the base of the joystick
- Use this template to trace on the walnut veneer (2 pieces)
- Cut out and glue together
- Glue veneer circle on the top piece
- Mark center and drill out with a 3/4" hole saw
Step 5: Make Rings
Use walnut veneer to make three rings:
- 1 1/2" in diameter 1/4" high
- 1 1/4" in diameter 3/8" high
- 3/4" in diameter 5/8" high
- Cut veneer into strips approximately 10" long and 1/2" wide
- Steam veneer strips until pliable
- Apply thin layer of wood glue to one side and wrap around jar/dowel/etc (I used a dowel, spice jar and a nail polish bottle)
- Fix with a rubber band
- Leave until thoroughly dried (8+ hours)
- Remove and cut down
Step 6: Assemble
Assemble box
- Glue top pieces together in a frame
- Glue bottom pieces together in a frame on top of the base piece
- Glue piece of cherry board to the underside of the top piece to create upper section
- Glue 1/4" walnut piece to the underside of the lid (traced 1/4" around bottom of lid as guide)
- Sand corners
For a simpler (and possibly more practical) single section box, here you could skip gluing the cherry piece. Instead, just glue the top frame to the bottom frame. You retain the look of the seam, however, this will result in one 1 3/4" deep box instead of a box with a 3/4" lower section and 1/2" deep top section.
Step 7: Cut and Glue Veneer
Joystick has two arrows at each quarter and seven small rectangles between each. Okay, technically, there are only three sets of arrows and on the top of the joystick it says "TOP"...but i prefer the arrows (and cutting out letters that tiny wold just be crazy).
- From the cherry veneer, cut out 28 rectangles 1/8" by 1/16" and 8 triangles 1/8" by 1/4" (trim two points of each)
- Glue around the inner circle to mimic marking on the joystick
Step 8: Finish
Shellac it up and you're done!
