3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Atmega16/32 Development Board With LCD
This instructable shows, how to do your own development board for Atmega16 or Atmega32 processors.The Internet is full of home made development boards, but I think that, there is room left for another one. This board have been very useful on my projects and I actually designed and made it to serve one of my project.
What it offers?
- ISP-connector.
- Adjustable reference voltage for AREF with trimmer.
- 8 leds connected PORTA with removable jumpers, so you can use leds also with another ports.
- Spike bars for PORTA, PORTB, PORTC and PORTD.
- Modified spike bar for LCD-screen (4 bit)
- rs232 serial port connector
- Removable rs232 module
- Regulated 5V
What you will need? (parts for main board)
- 1x Atmega16 or Atmega32 processor
- 1x crystal (It is your choice how many Mhz it will be)
- 2x 27 pF capacitors for crystal
- 1x 7805 voltage regulator
- 1x 47uF 16V capacitor
- 3x 100nF capacitor
- 1x DC-jack 2,1mm or 2,5mm (what ever you want use)
- 1x 1K potentiometer
- 8x led (any colour)
- 8x 330 Ohm resistors
- lot of spike bars
Parts for rs232 module
- Max232 IC
- 4x 0,1uF capacitors
- 2x led (green and red)
- 2x 330 Ohm resistors
- Spike bar
- D9-connector
Step 1The Circuit Boards
The Circuit Boards
There is circuits from the both boards and the pdf-file contains print out files from these boards. You can etch your boards from these pictures. The zip-file contains all Eagle-files from these boards. Feel free to modify these how do you want.
rs232.pdf(595x842) 10 KB
mega16.pdf(595x842) 17 KB
2 comments
Oct 20, 2009. 2:25 PMmoris_zen says:
 Great instructable !
I just purchased my new ATMEGA168 but can't seem to get it to load my first program .. I would be happy if you could give me a hand .
I have the RS232 (MAX) adaptor connected to my PC and tested (loopback) .
I just connected the VCC and GDM and tryed to send it a simple "blink LED" program with no sucsess .
I assume when I buy a new deice it is set to internal clock (as in DS) .
I assume it works by default in the RS232 in 9600 (8N1 - no hw ).
Any tips ?
May 6, 2009. 8:08 AMTXTCLA55 says:
HEY! I have a LCD screen, i need to hook it up to a Arduino using only three wires. One for Vcc, another for ground, and the last one for Com (or data). Any suggestions?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:iideetee
