3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Atomic Zombie's Carnage chopper bicycle
Step 33More primer
More primer
Once the first light dusting coat of primer is dry, you can fully coat the frame with primer (Photo 33). Again, shake the can often, and only make short back and forth stokes with the can held at least 10 inches from the frame. This will take a while and may use more than one can of primer, but will result in a run-free well coated finish. To get to this stage, I used the entire can of primer. Be sure to get the entire frame from all angles - lay on the ground if you have to.
This coat of primer should set for about an hour. How does your lawn look now?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
88
Author:KoolKat
