3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Atomic Zombie's ChopWork Orange chopper bicycle
Atomic Zombie\
Kids' bikes with 20-inch wheels are abundant at the dump and yard sales, especially the cheap steel frame units. These bikes not only take a beating, but they are outgrown in a year or two, so you will probably find a lot of them at your favorite scrap yard or city dump. These frames are easy to chop, and 20-inch bikes make great choppers, but unless you are only 4 1/2 feet tall, there won't be much leg room on one of these bikes.
The problem of size is compounded even more if the head tube angle is taken back to add more rake, as this pushes the handlebars even closer to the seat. At this point, your only option is to move the seat higher or farther back, creating either a goofy looking chop, or a flying death trap that pulls uncontrollable wheelies on so much as a sneeze.
To get a little more leg room on a chopper made from kid's 20-inch frame, two frames will be joined together in order to move the bottom bracket further up. The head tube will also be pushed forward, allowing for a nice long set of forks to be installed without creating a super tall wheelie machine.
More cool projects can be found at: http://www.chopzone.com and
http://www.atomiczombie.com
Step 1Find a donor bike
Find a donor bike
The sacrificial lamb is a typical steel girl's frame 5-speed bike (Photo 1), fresh from the garbage heap at the local dump. For this project, you will need two 20 inch frames, and the components to make one complete bicycle. Depending on how you join the frames, the condition of the front half of one frame and the rear half of the other may not be important, as you will soon see.
37 comments
Oct 16, 2011. 1:42 PMmuromec says:
Cool project! good work.
You dont want wide wheels ?
Mar 2, 2009. 10:47 AMl96470fps says:
du u arc or mig weld? oops i forgot, or tig?
Jul 16, 2010. 9:50 AMVulcanator says:
mig.
Feb 11, 2010. 6:18 AMTechnokid817 says:
 That's pretty tight and I know a thing or two about bikes considering I race BMX. Good job with this one!
Jan 22, 2010. 8:17 AMbob48220 says:
 brilliant... a fine piece of engineering
Aug 22, 2009. 2:33 AMsuparadbritishkid says:
sick liking the dubble sproket
Jun 22, 2009. 9:03 AMirishkorene says:
badass
Sep 20, 2006. 10:38 PMDanAdamKOF says:
That's seriously cool. If I had a bike like that I'd ride it all the time (walking is for suckers).
Jun 21, 2009. 5:57 PMMadrias357 says:
I'm thinking of something similar for a trike cause I'm tired of falling over with a standard 2-wheel with my box full of stuff. But I want it to look cool. Either that, or I'll make the Trike off-roadable.
Sep 19, 2008. 6:08 PMT.E.A. says:
ok my parents still make me wear a helmet and its one of the big fat ones does anyone have any ideas for one that looks halfway decent and still works?
Jun 21, 2009. 5:54 PMMadrias357 says:
Go to your local bike shop and look for one. I have one that's not too bad, and yet still works.
Mar 10, 2009. 2:55 PMomnibot says:
I'm 32 and wear a helmet. Mostly because a lot of people who get hit by cars or fall off when biking suffer crippling braindamage as a result. But get a cooler helmet.
Jan 14, 2009. 5:53 PMhyperactiveguy says:
It's good to wear a helmet...especially if you wipe out often, but that doesn't mean I wear one. Anyway, if it's one of those big skater helmets, you could do a custom paint job to match your bike, I'm sure any reasonable parent would accept your argument. Just sand down the existing paint (not all the way, just so it's rough)then spray paint a base layer, and paint whateever you want on top.
Jun 25, 2008. 2:33 AMchopperman says:
nice chop..so nice i made one for myself..but i used 24 inch frames..nd changed some parts...
Jun 24, 2008. 5:44 PMSkaBossDerek says:
Could this bike be made bigger by using larger frames?
Nov 25, 2007. 4:13 PMPacific Drift says:
TOP CHOP,....very artistic,...love the ghost sprocket.
May 22, 2007. 10:05 AMchopper king says:
i really like how clean your bikes are. They appear to be made from a factory. i'm working on a twelve footlong chopper right know. all i have to do is paint it. keep up the good work.
Mar 18, 2007. 7:25 AMpyroo5576 says:
sickkk im doin that to all my bikes in my garage
Feb 8, 2007. 11:54 PMchenkerchops says:
That looks deliciously dangerous.
Nov 9, 2006. 9:48 AMIllidan says:
cool thanks
Oct 11, 2006. 12:42 PMIllidan says:
would it be possible for a 13 year old to make this?
Oct 20, 2006. 4:52 PMzachninme says:
Depends. I know I could, but I don't know about the other 99% of kids in my school... (Then again, if you go here, then you can't be all bad :-) )
Sep 24, 2006. 11:27 PMsboger says:
What type of welder are you using? I am looking at this for a winter project, but want to buy the right components... I'm torn between oxy-acetylene, arc, wire-fed... Don't know which one would be best for scrap projects like this...
Sep 22, 2006. 3:03 PMTheThompsonFive says:
Aha! You have solved my goofy looky wheelie popping death machine problem.
http://static.flickr.com/60/162009890_726f28e588.jpg
I've been thinking of ways to stretch this and make it more ridable. I was planning on extending the stays, but some variation of the above will work much better.
Your book was what got me started on hacking bikes. I'm currently saving up parts to turn this: http://static.flickr.com/65/169664786_385a81144c.jpg into a hammerhead.
You rock!
Sep 21, 2006. 10:04 AMfungus amungus says:
Another cool project from you guys. Just got your book a couple weeks ago and totally dig it. Highly recommended.
Sep 21, 2006. 9:10 AMsambot says:
Nice! Do you flickr? This bike would be perfect for the Orange Bikes photo pool:
http://flickr.com/groups/orangebicycles/
Sep 21, 2006. 12:55 AMtrebuchet03 says:
another awesome build... I really love that extra chainring in there :P
Sep 20, 2006. 8:14 PMgigman says:
Wow, I want one! Thats really cool!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
88
Author:KoolKat
