3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Atomic Zombie's Firecracker kids' chopper bicycle
Atomic Zombie\
Choppers aren't just for grownups, dude! In fact, with the abundance of little kids' bikes at yard sales, scrap yards and dumpsters, it only makes sense that this had to be done. Even brand new, a 12-inch wheel kids bike will only set you back a little more than 50 bucks.
As for learning to ride a chopper, kids just don't seem to know the difference - they wobble around on the bike without a care in the world. Most kids that tried the small choppers that I made, could ride them on the first try. I guess if you're not used to a standard bicycle yet it may even be easier to master a chopper. Old dogs, new tricks, you get the idea.
More cool projects can be found at: http://www.chopzone.com and
http://www.atomiczombie.com
Step 1Choose the donor bike
Because of the size of the tubing on these bikes, and the fact that the rider will not weight very much, a single tube can be used to extend the frame into a chopper. Notice the oversized down tube on this bike (Photo 1), it will be easy to lengthen this to create a stretched frame chopper.
24 comments
Apr 2, 2010. 11:12 AMduckman633 says:
I wish i could weld 2 but i cant
do you what i should do
Jan 16, 2011. 6:38 PMI luv Duct Tape says:
learn
Jun 26, 2010. 7:48 AMTSC says:
Cool!!!!!!!!!!!!!
May 15, 2008. 2:35 PMfortneja says:
If you didn't need to extend the forks much, you could just use the fork off a full size adult bike. Just an idea if you want to do as little welding as possible.
May 24, 2010. 2:50 PMduck_tape_ says:
exactly what I was thinking.
Jul 25, 2009. 11:23 AMRobot Lover says:
my friend made an electro- magnetic one and had shockks
Jul 20, 2009. 10:43 PMcamholland says:
im like 16 and i have a motor ona bike like this i think it wud b sweet if i had it a chopper
Apr 8, 2009. 4:31 PMpandaboy292 says:
when i was little my grandpa put a steering wheel from a go cart on my bike.
Aug 11, 2006. 4:11 PMclickdeath says:
dunno if im into the lack of brakes, but kids seem tough enough to take a few tumbles every now and then!!
Jan 15, 2009. 5:00 PMhyperactiveguy says:
in America coaster brakes are the standard for kid's bikes (you pedal backwards to stop), not like in England or other countries where those handle brakes are used...coaster brakes give a cleaner look to the bike and don't wear down like other brakes.
Nov 11, 2008. 3:46 AMsory24712 says:
lol that why trees are here to stop us
Feb 28, 2008. 7:55 PMdavetp425 says:
It probably brakes when you pedal backwards; a lot of kids' bikes do that instead of a handbrake.
Nov 11, 2008. 3:38 PMmetaljoe0 says:
it's got caster brakes, thats what that little tab attached to the rear hub is for. you can see it well on the breakdown photo.
Dec 16, 2007. 5:01 AMbedbugg2 says:
so simple!
Jan 14, 2007. 5:29 PMlemonie says:
The before & after says it all, this chopper is way cooler than the bike you started with.
Sep 28, 2006. 6:53 AMVirtualJWN says:
Cool and nicely done. I built one of these for my younger cousin when I was about 12. Worked well on pavement. not so great on gravel. Caster (or camber????) on wheel changed too quickly to steer effectively.
Sep 28, 2006. 1:09 AMCrash2108 says:
This was on the news...
http://kutv.com/peterrosen
Second movie, near the end
Aug 12, 2006. 2:01 PMpazu says:
It's cool! I like it, but I don't know if I can make a modification like you or not.
Aug 26, 2006. 1:51 AMbigboybob says:
that is the pimp mobile right ther
Aug 13, 2006. 8:08 PMTheCheese9921 says:
i say get the kid a miny bike and let im go at it
Aug 11, 2006. 4:51 PMCementTruck says:
It might be cool to extend the pedal crank housing forward and use a banana seat. This way the kids aren't sitting so stiff and vertical, but rather laid, just like the bike. The banana seat could hang slightly over the back seat, and you could lean the handle bars back even farther. Just a thought.. Hmm....forget the crank housing extension. Can you say weedeater motor with a torque converter?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
88
Author:KoolKat
