3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Atomic Zombie's Granny's Nightmare bicycle chopper
Step 5Grind the edges of the fork crown.
The original fork crown is used as the base of the triple tree. The new fork leg extension tubing will be welded directly to the ends of the crown, so it should be ground slightly to allow for easy welding. Do not take too much metal out, just enough to make a good weld that will cover 1/3 or more of the new tubing's diameter. If you ground too much out, the fork legs will be too narrow for a front wheel, and major warping will occur to the conduit while welding.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
88
Author:KoolKat
