Attach Plastic Bottle Caps for Carpenter Bee Traps
27,963
27
12
Posted
Introduction: Attach Plastic Bottle Caps for Carpenter Bee Traps
kentdvm recently posted an Instructable for a carpenter bee trap, https://www.instructables.com/id/Making-Carpenter-Bee-Traps/
which uses two bottle caps connected together as part of the assembly. He used tape to connect the bottle caps, and here I offer another method that uses 1/2-inch metal grommets from a tarp repair kit. Photo is of one of my own variations of the trap, designed to fit under a small roof overhang. A separate Instructable for this trap will be posted soon.
To see my related Instructables, click on my username wherever you see it on this page, or enter unclesam in the home page search box. On the new page, click "view all __ instructables." On the next new page, click "NEXT" repeatedly to page and scroll through them all.
Unclesam
Step 1: Tarp Repair Kit
I happened to have a kit for replacing metal grommets in tarps, bought years ago from some mail order tool supply company. It contains 1/2-inch metal grommets and metal capture rings, a tool for punching a hole through the tarp, and two tools for easily and neatly setting the grommets.
Step 2: Punch Holes in Plastic Caps
The kit's punch made clean holes in the caps when pounded against a wood backup block. The holes need to be enlarged slightly by rattail file or sandpaper.
Step 3: Set Grommet Using Ball Peen Hammer
These green plastic caps are too thick to use the metal capture ring, so the grommet is set without one. These caps do not have an inner seal ring that needs to be removed. The tarp repair kit's setting tools will not fit into the caps, so the grommet is spread by tapping the ball of a ball peen hammer onto the metal using a second hammer. The backside of the grommet is supported by the flat end of a metal rod during the peening.
Step 4: Caps Connected Without Capture Ring
Two green plastic caps well connected without metal capture ring.
Step 5: Remove Seal Ring From Inside Blue Cap
Some caps have an inner seal ring that must be removed to reduce its thickness. The ring is most easily removed from this type of cap using a knife through the hole punched in the cap.
Step 6: Remove Seal Ring From Inside Clear Cap
The seal ring is most easily removed from this type of cap, whose plastic is very thin, before the hole is punched through it.
Step 7: Blue and Clear Caps Attached Using Capture Ring
The plastic in these two caps is thin enough, with their seal rings removed, that the metal capture ring can be used with the grommet. The grommet is again spread using the ball of a ball peen hammer, then somewhat flattened using a flat-ended metal rod tapped with a hammer.
Attaching the caps together using a metal grommet should provide a long-lasting connection in the carpenter bee trap application.
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
12 Comments
thanks to this post and others like it. our native bee species are disappearing from the planet at an alarming rate. i guess u dont love honey at all.
Carpenter bees don't make honey. You could put one of these traps every 50 feet all over North America and you wouldn't kill off those carpenter bees. The main reason native bees are disappearing is because of too-neat suburbs. Carpenter bees need dead wood to live in, and most suburbanites remove that as soon as possible because it's not pretty. I have a stand of dying walnut trees just across my property line and it produces so many carpenter bees that my bee traps consistently get between 20 and 50 bees a piece in the spring and fall, and I am still drowning in live ones. These traps do kill carpenter bees. They are not effective enough to eradicate carpenter bees.
If you want a bottle of dead bees though, these rock!
.I took an old discarded La Crosse raquet (spring trash day) that I found some on the side of the road. Lashed it to a long birch sapling with two auto hose clamps. It is great fun to swat those nasty hole boring bees with. When I hit them I hear a "pong" sound. Then I run over to them and they are usually D.O.A. ! Very satisfying!
Transquesta dn unclesam: you both need to do more research on Carpenter Bees. They do not sting. They do 'seem aggressive' but they are inquisitive and pesky as a toddler with 'why is this and what is this'. They catch their reflection in your eye and they want a good look at themselves! I've noticed they like it when I work on something that takes oil (tiller, lawnmower). The flapping of their wings do make an unsettling noise buzzing about your head but I've yet to have one attack me. Quick detection is, A bumble bee (which will sting) doesn't have the big black bumm (rearend).
Carpenter Bees cause far less damage than Carpenter ants or termites.
So once your bee is in the bottle...what then?
The bees may not cause too much damage but that 18" cock-headed woodpecker will when he rips your fascia apart to get to the larva. Incredible bird but I have only seen once. I'm not willing to grow carpenter bees just to see one though! :^)
I do need to make about 3 of these traps.
Actually, I was stung once when I mowed too close to an old building, so I Googled and found out that the females will sting. The males just love to dart at us, scaring the bejez out of us. Thanks for post, since know I know a little more about these pesky lil beasts.
If you do not have the time or the tools, place a couple moth balls in the general area and they will leave the area. Tried it and they were gone the next day. Seen it on instructables. Doodado
I like the mothball idea. Quick and cheap. Used them once to get squirrels out of a chimney.
Love it! Great solution for connecting the caps. Much more permanent than my tape. Thanks! kb
What baits the bee (typically the female WITH a stinger) out of the hole into the trap?
