Attachable Table Cubby
Introduction: Attachable Table Cubby
We wanted our classroom to have an easier way of storing and turning in our Design and Engineering Notebook projects.
Foam core
five 8" x 8"
three 2" x 10"
24 pins
Table saw/scissors/exacto knife
Step 1: Measure Out Your Foam Core
Grab a sharpie or pen
Three 2" x 8"
Five 8" x 8"
Step 2: Use a Dremel Moto Saw to Cut Your Final Measurements.
If you don't have a dremel moto saw that's ok, you can use scissors or an exacto knife.
Step 3: Pin Your Box Together
Pins are about 1.30"
Step 4: Slide in the Dividers and Pin Them to the Box
Step 5: Zip Tie the Box
For this step we found that the type of foam core we used have these square holes in them, which made it easier to secure a string/wire/zip tie around the box.
If you want to use zip ties here's what you do:
Get five zip ties (for us it took five to get around the pole of the table)
Connect zip ties together
Stick each zip tie on both sides of the box through the small square holes.
Ours had three zip tie attachments.
Step 6: Create a Base Underneath Your Box
We used a different kind of foam core when creating our base.
The sheet was a lot more thicker than our box.
The front part should be 4" high, covering the lower half of the box.
Don't fully cut this foam core, it just makes the construction process easier to bend it, rather than fully cutting through.
Side walls should be 2" x 9.5"
Hole should be 2" x 3.5"
Step 7: Create a Hole in the Base
Hole is 2" x 3.5"
Step 8: Congratulations Man, You're Cool!
Step 9: Here Were Our Prototypes
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    These little cubbies look good. I like the clever use of the T pins!
    Thanks man, originally we used glue but the pins worked way better.
