Attiny85 EMF Detector
Introduction: Attiny85 EMF Detector
This is a simple tutorial to create an EMF detector. You can use Arduino for this job, but is better use a microcontroller called Attiny85. It is possible program it throe the Arduino interface.
What is a Magnetic Field [from Wikipedia]
An electromagnetic field (also EMF or EM field) is a physical field produced by electrically charged objects. It affects the behavior of charged objects in the vicinity of the field. The electromagnetic field extends indefinitely throughout space and describes the electromagnetic interaction. It is one of the four fundamental forces of nature (the others are gravitation, weak interaction and strong interaction).
The field can be viewed as the combination of an electric field and a magnetic field. The electric field is produced by stationary charges, and the magnetic field by moving charges (currents); these two are often described as the sources of the field. The way in which charges and currents interact with the electromagnetic field is described by Maxwell's equations and the Lorentz force law. From a classical perspective in the history of electromagnetism, the electromagnetic field can be regarded as a smooth, continuous field, propagated in a wavelike manner; whereas from the perspective of quantum field theory, the field is seen as quantized, being composed of individual particles.
The materials of this project are:
Many of these components are in this KIT
Step 1: The Circuit
First step is create a circuit on the breadboard. Use a breadboard like in photo and try the circuit before solder it on protoboard. After the test you can use a protoboard to connect the attiny85 to leds and antenna.
For upload the code on Attiny85 you can use this shield and a programmer, or your Arduino UNO.
Step 2: The Code
See the code also on GitHub:
// EMF Detector Attiny85 and 4 led v1.0
// 23.10.2015
// original code/project by Aaron ALAI -
// modified for use by Giovanni Gentile -
#define NUMREADINGS 15 // Number of readings
int senseLimit = 15; // Raise this num to decrease sensitivity int val = 0; int antenna = A2;
int LED[] = {2,0,1,3}; // After verify the position of red green and yellow leds
// Variables for smoothing
int readings[NUMREADINGS];
int index = 0;
int total = 0;
int averange = 0;
void setup() {
pinMode(2, OUTPUT);
pinMode(0, OUTPUT);
pinMode(1, OUTPUT);
pinMode(3, OUTPUT);
pinMode(A2, INPUT);
// Test leds on start
for (int i=0; i<4; i++) {
// Initialize all the readings
for (int i = 0; i < NUMREADINGS; i++) {
readings[i] = 0;
void loop() {
int val = analogRead(antenna);
if(val >= 1){
val = constrain(val, 1, senseLimit); // turn any readings higher than the senseLimit into the senseLmit
value val = map(val, 1, senseLimit, 1, 1023); // remap the values
total -= readings[index]; // subtract the last reading
readings[index] = val; // read from the sensor
total+= readings[index]; // add the reading to the total
index = (index + 1); // advance to the next index
if (index >= NUMREADINGS) index = 0;
averange = total / NUMREADINGS;
if (averange > 50) {
digitalWrite(2,HIGH); }
else {
digitalWrite(2,LOW); }
if (averange > 350) {
digitalWrite(0,HIGH); }
else {
digitalWrite(0,LOW); }
if (averange > 750) {
digitalWrite(1,HIGH); }
else {
digitalWrite(1,LOW); }
if (averange > 950) {
digitalWrite(3,HIGH); }
else { digitalWrite(3,LOW); }
Step 3: Install Arduino IDE and Programming Attiny
Go to
Go to Download (
And select the previous installation of Arduino IDE 1.0.6. This is very IMPORTANT because with the new version of Arduino IDE is impossible to program the Attiny85. After the installation of attiny85 package you can select the Attiny models.
After installation of IDE you can programming the Attiny85 by your Arduino UNO. Then following this tutorial
Step 4: Final Result
I have used a perfboard and 4 little leds. The result is more pretty. A micro, open source, portable and geek EMF detector.
The electromagnetics fields now are visible. I use this in my courses. With this I demo the force of electromagnetic field. You can use this EMF detector, near a microwave or fridge or a big power supply. Also the ventilator generate a big electromagnetic filed.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Science of Cooking
    Science of Cooking
I'm kinda of new at circuitry and I don't quite know how to work the circuit on the breadboard, could you help?
What resistors do you use? I'm pretty sure you're not using non-standard 40ohm ones.
The 4 resistors are for leds. The resistor for probe is 1 M ohm.
Excellent circuit! Just finished my own version of your project and wanted to say thanks forbthe inspiration
Wooo great! Post some photo if you can.
Thank's for your message. I make the Instructables just for people like you :)
hi thanks for the information I was wondering if you can modify this circuit to measure the level of emf for a particular frequency band .
Hi, you can change the resistance for modify the frequency.
can you suggest a combination to measure power of 10khz to 10ghz band
Hi, I was wondering if you had any advice for someone who wants to add a buzzer sound that increases in intensity (similar to a Geiger counter) as opposed to LEDs?
you can use a simple buzzer. Then Arduino have an excellent library to use the piezo buzzer. You can use "tone(xx,xxx)".
