3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Audible AC power-off alarm
I have a freezer that is located in the garage. During a recent renovation in the garage, the electrician was required to put all the circuits in the garage (including the
freezer) on a GFCI (Ground Fault Circuit Interrupter). He warned me that if the GFCI trips, there might be no indication inside the rest of the house that there is trouble,
and I could potentially lose the contents of the freezer before I notice the problem. He also said that to the best of his knowledge, there is no audible alarm available on
the market.
I checked around and could not find one, though I did find several rechargeable flashlights that can be set to automatically come on in the case of a power failure. One
such product is available at Radio Shack under the name "Eton American Red Cross Blackout Buddy" (part # 20-019) for $14.99.
The Blackout Buddy has three LEDs at one end and one LED at the other. There is a red switch on the top of the case that turns on the three LED end and an
"OFF/Auto" switch on the side that turns on the one LED end. The three LEDs will only light when the Blackout Buddy is disconnected from AC power and the top cover
switch is turned On. The one LED end is a nightlight and will only light when the side switch is in the "Auto" position and the room is sufficiently dark.
Radio Shack also sells several buzzers that could be attached in place of one of the LEDs. Once complete, when the LEDs light up, the buzzer also goes off.
Some of this project sounds like an advert for Radio Shack. Other than living in the Ft. Worth, Tx area, I have no connection with Radio Shack. I will not be
compensated in any way if you purchase any or all of these components at Radio Shack.
Of course it must be noted that making these changes to the Blackout Buddy will definitely void its warranty.
Step 1Assemble the necessary parts
For this project, I purchased the following at Radio Shack:
Eton Blackout Buddy   (RS Part # 20-019)  $14.99
Pulsing Piezo Buzzer  (RS Part # 273-0066) $5.49
You will need the following tools:
T6 Torx driver
Small Phillips screwdriver
Small flat screwdriver for separating case
{all three of these are available as part of a set at Radio Shack (RS Part # 64-071)}
Diagonal cutters
Soldering iron
Solder
Hot melt glue gun
Hot melt glue
4 comments
Sep 19, 2010. 10:20 AMAdam Manick says:
You could also use a relay a battery and a buzzer so when the power goes off the relay activates the buzzer.
Oct 10, 2010. 4:14 PMAdam Manick says:
Your welcome. I hate it when you post an instructable and nobody comments. You can’t learn that way. I rated your instructable 5 stars because you actually had the patience to reply to my comment. Thank you
Jul 29, 2011. 9:41 AMdrbill says:
I have a relay connected to a 25 amp switching power supply that is activated when the power is on. Power is siphoned off to charge a lead acid tractor battery and has a current limiting resistor to avoid over charging.
So, as the power is on the relay is on and the battery is charged and I can operate a VHF radio transmitter off the last 2 power taps. [there are 3 taps]
When the power goes off in the house I can still operate the radio because when the relay loses power the radio gets it from the battery.
It is a simple Un-Interruptable Power Supply. cost about $50 to build with all the power taps and stuff.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:swake
Middle aged unemployed telecom worker bee waiting for the Obama economy to improve enough that I can get another job. In the mean time, I'm learning about electronics and taking a class in Java.
