loading
Step 2: The Circuit
For IC1 I used an LM358N dual operational amp. I prototyped the circuit using different op amps. They all worked, so use whatever you have in the parts bin.
IC1A is configured as a comparator. If the +input goes lower than the -input, the output goes low, which will turn on Q1. That is, if the resistance through the probes is less than 10 ohms (or any other value of R3) the output will go low.
IC1B is square wave oscillator. I got the circuit out of the LM358 app notes. As shown, the output frequency is around 1KHz. This can be varied by replacing R4 with a potentiometer.
When the transistor Q1 switches on, the output of IC1B (a 1KHz square wave) passes through the emitter, and switches Q2 on and off at 1KHz. The current from the collector of Q2 drives the speaker.
The emitter of Q1 originally drove a piezo transducer, but the results were not so good. Adding the power transistor Q2 gives enough current to drive a small speaker. The volume can be adjusted by replacing R9 with a potentiometer.
Build it. Use it. It makes a fine addition to any test bench.
Seeya
wotboa
<p>Nice</p>
<p>brilliant absolutely brilliant! </p>
<p>Nice instructable, with good explanation about how the cicuit works, i&acute;ve made on continuity tester from a 555 because it was the only option i found. I&acute;ll try this.</p><p>Thanks</p>
<p>Thanks lean04<br>After building the tester, I wondered why the design (or the concept, really) didn't exist. <br>All other testers I've seen (including the 555) inject a voltage, then rely on current flow to activate a lamp or buzzer. This greatly increases the possibility of damaging sensitive components. <br>This tester measures the circuit at the <em>input</em> of the op amp, and uses ground as a reference. There is very little danger of damaging installed components.</p>
<p>Recently i saw a video tutorial from Dave Jones about opamps, and he said something that relates to this. When talking about the &quot;rules&quot; of opamps he mentioned that no current flows from or through the inputs. So the damaging components risk might be none...</p>
<p>test</p>
About This Instructable
9,098views
77favorites
License:
Bio: I ain't no physicist, but I knows what matters.
More by wotboa:Canon A590 Shutter Release Cable Mini Diamond Grinding Disk for Drill Bits Emergency Lamp from a Cell Phone
Add instructable to:
