Audio Amplifier Circuit | Using 555 Timer | Easy Electronic Project | DIY
Published
Introduction: Audio Amplifier Circuit | Using 555 Timer | Easy Electronic Project | DIY
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hello , Today In This Tutorial I Am Going To Show You Step By Step ( Home Made )
How to make Audio Amplifier Circuit with the help of 555 Timer -- IC.
This Electronic Project is Very Simple Easy and DIY (Do It Yourself)
Step 1: Hardware Required
  • 555 Timer ICC
  • Condenser Mic
  • 8 Ohm Speaker
  • BC547 Transistor
  • Resistors - 470 Ohm, 1k, 10k, 47k, 100k, 680k ohm
  • Capacitors - 10µF, 1nF, 100nF
Step 2: Circuit Diagram
Step 3: Working Explanation
555 time IC is very powerful and versatile IC, it can be used in many forms. In this tutorial we are going to see how a 555 IC can be used as Audio Amplifier. A low power audio signal can be amplified using 555 Timer IC.
This circuit is divided into two parts: part one is Preamplifier circuit, which consist a BC547 transistor, a Condenser Mic and some resistors & capacitors. Second part consist a 8ohm speaker and a 555 timer IC, which is oscillating in Astable multivibrator mode, with approx. 66KHz frequency.
The audio amplifier circuit is shown in above diagram. Control PIN 5 of 555, has been used here which is generally kept grounded through .01uf capacitor. Control PIN 5 is the point of 2/3Vcc inside the 555 timer IC, so we can change this 2/3Vcc voltage through this PIN. And changing the voltage at this PIN change the width of output pulse, irrespective of value of RC components in 555 timer circuit. It follows the same principal of Pulse Width Modulation (PWM) to modulate the output wave. We have used this functionality of Control PIN in this circuit.
Speaker does not respond to high frequency, so when there is no voltage at control PIN 5, speaker doesn’t produce any sound. When we create some sound near Condenser Mic, that sound is converted into electric signal by the Transistor, and this electric signal is fed to the control PIN 5 of 555 IC. The output pulse at PIN 3 modulate due to this voltage at control PIN, and speaker detects this DC component of Output pulse and produce sound. Basically when there is voltage at PIN 5, width of the output PULSE increases for a moment and that is detected by Speaker.
Resistor R1 is used for biasing of condenser Mic and R2 and R3 is used to provide proper biasing to transistor. We can test this circuit by blowing some air from mouth towards the Mic, the speaker will generate sound accordingly, as I have done in the Video.
Step 4: Datasheet
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
