Audio Amplifier Using TDA2050 32 Watt
Introduction: Audio Amplifier Using TDA2050 32 Watt
Audio amplifier using TDA2050 IC max output of 32Watt
Step 1: Components List
2x1K Resistors
2x22k Resistors
2x1000uF Capacitor
1x2 Ohm Resistor
1x0.47uf Cap
1x20K Potentiometer
1xBridge Rectifier
Step 2: Power Supply
The circuit uses a dual power supply to build the power supply use a 12V 5Amp transformer which gives a output of +12 And -12 Volt
Step 3: TDA2050
The IC gives a maximum power of 32Watt at 4ohm use a heatsink for the IC it gets very hot while in opration
Step 4: Circuit Diagram
Use circuit diagram to build the circuit you can also build this circuit on breadboard
Step 5: Stereo Use
For stereo application you can build a same copy of this circuit for the other channel
Step 6: OUTPUT
use a box enclosed speaker at output it gives a better bass output
Step 7: Sound Test Video
Step 8: Building the Circuit on Zero PCB
For a good connection than breadboard we can build this circuit on Zero PCB
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    my amplyfier used TDA2050A are buzzing. please tell me the cause?
    Check for any shorts.if its ok try adding capacitors to the power supply
    The ori version of TDA2050 has been discont...on 2012..Right now only the clone of TDA2050 on the market...This clone version 25W only..The ic protection not guaranteed 100% work.3A max...nomore 32W TDA2050 now...
    For the price...on my country...TDA2040 $12.50 .... TDA2050 clone only $7.45..
    TDA2040 more stable on low voltage .
    hello sir, can you please tell to me what is the cost of TDA2050 ic ? thank for the reading.......
