3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Audio Amplifier
Audio Amplifier
This is a simple (maybe) instructable on how to make an audio amplifier using a LM386 audio amplifier chip. The cup helps with the sound ;p.
Just found this.  Check it out, looks decent
Step 1The Parts
The Parts
I'll say this right now: Special thanks to josepino.com. This website has the greatest instructions and the easiest-to-read circuit diagrams
You will need:
-100k Potentiometer
-.1 micro farad capacitor
-220 micro farad capacitor
-10 micro farad capacitor --only necessary for the 200k boost loop
-LM386 microchip (or whatever it's called)
-Solder
-Soldering Iron
-small circuit board
-headphone jack
-speaker --http://www.josepino.com/circuits/index.php?howto-speaker.jpc--make your own
Optional
-plastic cup
Note: I added a breadboard that I drew up from the circuit diagram, so if someone wanted to double-check it that would be nice
106 comments
1-40 of 106next »
Mar 18, 2012. 10:58 AMuncle frogy says:
sorry if this is a bother but while amps are rated in watts we do not hear watts we hear in a scale rated in dB's. Watts alone are not enough what really determines the volume and the quality of the sound we hear is the speaker, the driver. All speakers are different you can get a lot more volume (dBs) from a more efficient speaker given in the SPL number of the speakers specs. xx db @ 1W/1m the higher the number the more efficient, the louder given the same amount of power (watts) supplied a SPL number of 99 dB 1W/1m will be louder and more efficient than one with SPL 90 dB 1W/1m.
when selecting speakers look at the SPL number and the power handling (watts), match and balance them to the amp intended. hard to do when using preassemble speaker cabs. though when watts is generally all you are given.
I like the cup! I used a cutoff water bottle for a similar effect. ;-)
uncle frogy
Dec 29, 2011. 8:41 PMWakeUpWolfgang says:
i am trying this but I am having a hard time on my beadboard only thing that is different is i am using LM358N would it work using it?
Dec 30, 2011. 4:58 PMWakeUpWolfgang says:
I was just wondering I knew it could be used and it is all I have. I will go to jameco and buy the LM386 and the mpf102 for another project.
Nov 15, 2011. 8:06 PMnodoubtman says:
the sound is too noisy i cannot understand anything :(
please help me!
thanks!
Nov 9, 2011. 1:55 PMjablome says:
i built the circuit on a breadboard, but instead of hooking it to a speaker i hooked it to a female headphone jack. it worked perfectly, but when i built it on the circuitboard theres no bass at all
Oct 31, 2011. 11:29 PMdepotdevoid says:
Hey killersquirrel, I used a stripped down version of this circuit in my Human Dalek costume this year!  Thanks for the instructable!
Oct 24, 2011. 11:08 PMmak24 says:
the circuit is too noisy...
Jul 18, 2009. 9:18 AMcarik says:
i also made this circuit. first on a "bread board" by following the "bread board" diagram and then made the circuit on a circuit board which i had made following the circuit diagram. and it is sort of working but with extremely bad sound quality whereas it worked very well on the "bread board". i have recently noticed that on the circuit diagram the 7th pin/ leg of the chip isn't attached to anything whereas on the "bread board" diagram it is the 6th leg that is not attached to anything. is this the reason why my circuit board is not working? please get back to me
Oct 22, 2011. 10:06 PMmak24 says:
yes!!
your power source or Vcc as we call it should be connected to the sixth pin of the LM386 IC but on the bred board it is shown on pin7, just change the ports..
and little bit more info:
pin 7 is for bypass any high voltage between 4 to 18 volts will cause the output to be a bypassed one that is there wud be no amplification , you will het the same low power output you received from the mp3 player or you phone or whatever your source of signal was
Oct 22, 2011. 9:54 PMmak24 says:
correct me if im wrong but shoudnt pin 7 be left alone...
its for bypass
you should have com\nnected the power port to pin 6 on the right hand side..
well you know that coz your speakers worked butthe schematics on the bread board are somewhat wrong
Feb 6, 2010. 12:22 PMn0ukf says:
Why is the schematic so tiny? It's hard to see once it's cluttered with the yellow boxes.
Sep 23, 2011. 2:12 AMDavid97 says:
He should put a un-marked version of shhematics
Jul 16, 2010. 11:14 AMknektek says:
All of this wattage business is very misleading. It doesnt mean that the higher the wattage the more the quality of the sound. You need to 'tweak' the system so that you can produce the best sounds.
Jul 18, 2010. 12:12 PMknektek says:
By tweaking the system, I mean by copying the circuit onto a breadboard and instead of the caps and the resistors use variable caps and potentiometers. With those experiment and see what combo makes the best sounds, use the combo on the circuit board.
Jul 14, 2010. 1:59 PMknektek says:
for more gain, use a resistor in series after the cathode of the cap. A 1.2K resistor would go great!
Mar 15, 2010. 4:38 AMrodeljames says:
can this amplify on a computer speaker??
if not what device should i usefor this amplifier...
can you also teach me how to connect the audio plug..because i cannot understand the instructions...
thank you
Nov 23, 2009. 11:59 AMemedina94 says:
 will this amplify a guitar or bass. i need a portable amp
Jan 30, 2010. 4:44 AMJodex says:
Well, the watts don't always really tell the real power of the amp. I have a Roland Microcube and it's two watts and you can get very loud sound out of it.
Jan 30, 2010. 8:08 AMJodex says:
Yeah.... Microcube is not the best bass amplifier, but really great with guitar! Enough bass.
Nov 3, 2009. 5:43 AMknoxarama says:
Would an LM393 chip work?
Sep 28, 2009. 10:19 PMpancho del rancho says:
okay so u connect ground from the mp3 line im using to the battery then to the speaker
Aug 17, 2009. 6:16 PMpraveer says:
Hey, awesome instructables. But I have a question. I am using an 8 ohm speaker, and have all the parts right, except for that last capacitor, (220 uf) which i replaced with a 470 uf; but the lm386 gets kind of hot, if I give it a 'greater that 6 v' input, allthough when I supply it with 4.5 volts, it gets slightly hot. I am casing this, and don't want to burn out the audio op-amp, so I would really appreciate it if you could help! Thanks! (And I read somewhere, but didn't understand, that the gain or impedence or load must match...i didn't understand)
Aug 6, 2009. 12:26 PMun0 says:
Is R1 control the amount of power going to the speaker (volume control)? and can you place a 10K potentiometer (variable resistor) between the capacitor and pin 8/1 for controllable gain?
Aug 3, 2009. 5:25 PMtoxicgasleak says:
I have it all wired on a breadboard but the sound quality sucks. does anyone have any tips on improving the sound?
Jul 31, 2009. 9:34 AMpancho del rancho says:
um is there some sort of filter
Aug 1, 2009. 2:29 PMpancho del rancho says:
huh im new like to clear the music cuz i hear sometimes that once is on the copper board the quality goes down im new like a said so yea help da news
Jul 1, 2009. 7:15 PMrkr says:
I made this circuit... it didn't work that well at first, but I experimented around and got it to amplify much more. If anyone cares to know, it will work better if you solder the signal wire and the middle lead of the pot together, then tie those to (a separate, and I stress SEPARATE) ground. You can try it if you don't mind not having a volume control on the board.
Jun 18, 2008. 7:20 AManerudhan says:
we could also use the LM380 IC ...... it has output power of 2.5 watts..... and also built in heat sink.......... ;)
Jun 19, 2009. 3:55 PMhackerlife says:
Would the schematics for that be the same as this? Cuz if you ask me, 2.5 watts sounds like the way to go
Jun 15, 2009. 10:43 AMhackerlife says:
Hey man, I really gotta thank you for puttin' this up, I've been looking for a way to amp up some speakers for a while now! (I want to wire up my backpack... lol) So I can pretty much get everything I need at, oh, say, like a RadioShack, right? I don't know much 'bout circuitry, and a few of this parts seem a little specific... Like the LM386 chip... What the heck is that?!! Thanks again though
1-40 of 106next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:killersquirel11
