This Instructable show how to make your own audio crossover.
My circuit garranties excellent high class audio quality.
Just a new design to reduce crossover frequency losses.
In this instructable you'll need the folowing items:
A drill
Pcb board
A soldering iron
Deoldering Pump
Ferric Chloride or any other Cooper echent
Solder
A horizontal drive transformer ( found in televisions)
10uf and a 2.2uf non-polarized capacitor
1.5 mm to 3.5 mm drill bits
A speaker box with an tweeter and loudspeaker
A digitial or analog multimeter
A permanent maker
Styrofoam Plate
Six strips of wire preferable three different colours about 1.5 metres
Goggles
Gloves
Surgical Alcohol
Remove these ads by
Signing UpStep 1Summary Of Operation
It can be placed on a breadboard with ease, overall it shows you how to connect it.
Well the transformer that i used can be found in a crt television set and it must be selected based on the power rating of your speaker.
I have a 15W Loudspeaker and a 5W tweeter this transformer is fairly small, so if you plan to have speakers that are very powerful i advise you to get a transformer of similar ratio but bigger. The transformer's ratio is 1 : 5.
Its primary resistance was 0.8 ohms and secondary 3.4 ohms
The same goes for the capacitors the voltage range is small like 16v -50v for small power applications. As you increase your output power the voltage of the capacitors must increase to the range of 100v -250V. The value of the capactors usually stay the same. Use non polarized capacitors because they wouldnt be damaged by the alternating voltage.
comments
Add Comment
Add Comment
