555 timer based plasma speaker by Alex1M6
Contest WinnerFeatured
Step 7: How does it work?
The 555 timer generates a square wave of a frequency and duty cycle determined by the potentiometers and capacitor across pins 8-7 and 7-6,2. This square wave is applied to the gate of the MOSFET turning it off and on many times a second (tens of thousands) thus allowing pulsing current through the primary coil of the flyback at a frequency generally in the 30-50khz range.
When an audio source is fed into pin 5 of the 555 chip it will actively change the duty cycle and frequency of the square wave to the sound waves of the audio source. This is audible in the arc via the changes in air pressure surrounding the arc, and as it is an audio signal altering this pressure we can hear it as sound.
If you have an oscilloscope then you can view this square-wave by connecting your scope probe to pin 3 of the 555 timer. Connect the scope probes ground clip to circuit ground.
-max- says: May 23, 2012. 8:51 PM
i am working on this, you can see my instructable on it called "build a singing arc (plasma speaker) (ongoing project)"
-max- says: May 23, 2012. 8:49 PM
is it possible to make the 555 circuit w/ distinct frequency and duty cycle control, instead of one controlling both, and the other controlling just frequency?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
