asimo says: Oct 3, 2011. 7:47 AM
I soldered all of the LEDs without using flux. I would say that if you have a decent soldering iron with a fine tip and a high quality solder with a flux core, flux is not absolutely necessary, although you will probably do a cleaner job if you use it.
ledartist (author) says: Oct 3, 2011. 7:51 AM
You must be very good with your soldering iron!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
