I use a "windowed in" porch.
You will need
Tubing/garden Hoses
Sub-Pump (i used a 500 watt made for dirty water)
Shelving
Outlet Timer
Plastic Bottle Caps
Hot Glue Gun lost of glue sticks
A awe on any sharp pointed thing you can use to poke holes in.
Scissors Sharp enough to cut garden hose.
A plastic barrel the size depending on how much tubing your going to need
trays as big as the shelves if they are not solid to catch water
Seeds
Seed starting containers
Potting soil
Remove these ads by
Signing UpStep 1Step One: Arrange Your Shelving
The plastic shelves i drilled a hole into, and at the bottom they are linked with a drainage tube, into a smaller bucket.
Under the metals shelving i put a big plastic tray, i got these from a pizza shop that was going to throw them away.
MAKE SURE THE SHELFS HAVE ENOUGH SUNLIGHT, the place i set this up at has a lot of sun, So i did not set up any addition lighting here.
sub is short for submersible pump thats what this is, this is not a sump pump,
its an Awl, not an awe. I think most can figure out what you meant but it might help the ones who get lost at that point.
I've go a water timer I picked up for $20 last year. if I attach that to a spicket on a 55 gallon drum I could have this system gravity fed.
or if someone was really inclined a hose valve a servo and a moister probe and wire the thing in to a computer.
futuregarden.com/hydroponics/smartvalve.html
Note that that product doesn't take care of pumping water back up. But since it gives the plants just enough water, a single gravity-fed supply should be rationed out with no runoff.
Someone should totally do an instructable on a DIY version of that valve which is more customizable.
