loading
Step 4: Wire the Rectifier.
Of course you can use individual diodes to make a bridge rectifier. I found it easier to get a rectifier ready to use. I bent the input (AC) leads in one direction and the output (DC) leads in the other direction. This made a convenient base or support for the rectifier.
It is a good idea to use a heat sink when soldering diodes to protect them from too much heat. Put a rubber band on the handles of a needle nose plier and clamp the plier jaws on the lead you want to solder.
Watch the output polarity so the + terminal on the rectifier connects to the wire for the red aligator clip. I simply glued the bridge rectifier to the plywood with hot glue. Notice the strain relief for the output cord.
To use: Select 6 or 12 volts with the switch. Connect the red aligator clip to the red battery terminal and the black to the black. Set the base of the charger someplace safe. Plug in the AC cord. Disconnect the AC cord after 12 or more hours. Then disconnect the aligator clips from the battery. This prevents sparking that could possibly ignite hydrogen gas from the charging.
I have also used this charger as a power supply for things like a hot wire cutter. A smoothing capacitor is not necessary because batteries charge better with slightly choppy current.
Do I need to purchase a new transformer? I have the one with just two wires. Won't that work?
A transformer with two output leads will work fine for a single output voltage. Mine had a center tap and that allowed me to make a dual voltage battery charger.
Did everything identical to yours, i thought. When i plugged it ,transformer smoked. Transformer was a jameco 221356 -to a NTE 53016- OUTPUT. what might be wrong
My first thought is the switch for selecting 6 volts or 12 volts is wired incorrectly and creates a direct short across the secondary of the transformer. <br><br>I observed a great trick when I saw a furnace repairman replace a transformer on the ignition system. He placed a fuse in line with the transformer. If anything went wrong, the fuse blew and protected the transformer.
I dont have a 6 or 12 volt selector switch. Transformer only has 2 wires coming out, no center tap. <br>
Tried again with new transformer, worked great. Im assuming first one was bad. Thankyou for your time and help
<p>I am glad it worked for you. I am sorry you had to go to the expense of another transformer. Thank you for the update. </p>
<p>Sorry. When you said yours was exactly like mine, I assumed you had a center tap transformer and a voltage selector switch. I suppose I would disconnect the transformer from the rest of the circuit and then connect an ohmmeter to the rest of the circuit to see if it presents a dead short to the transformer. If you have a diode check function on your multimeter, you can check to see if the diodes in the bridge rectifier are funtioning as they should and not presenting a shortcut that allows too much current to flow where it should not. All of this assumes there was no problem with the transformer before you began.</p>
<p>Great instruction. Actually we can <a href="http://batteryrecover.com" rel="nofollow">recondition batteries</a> - it's very easy to do.</p>
How can we add a automatic shatdown if the battery is fully charge??
That is beyond my knowledge. I believe you can find circuits for doing that on the Internet. It would be complicated. A simpler thing would be to use a common household timer on the power supply to the charger. Allow the charger to run the number of minutes you know will charge your battery. <br><br>I did once buy a battery conditioner for auto batteries for about $30. It automatically keeps a 12 volt auto battery fully charged.
Dr. Bill
Hello Dr. Bill<br>I have 12v schumacher battery charger, the transform inside as I look at, the secondary have 3 output tap, center tap go to negative output, both outer taps go to two diodes(half wave rectifier). The AC voltage from 2 outer taps I got 29volts . How can I wire this charger to become 24volts DC charger?
<p>I made a diagram. Ignore the center tap. Use the two outside taps and a bridge rectifier or make your own from four diodes big enough to handle the maximum amperage you expect plus some for safety. The output voltage will be a bit larger than 24 volts, but not much. Check the polarity on the output before connecting to a battery.</p>
<p>I added a small value electrolytic capacitor across the output of the rectifier to smooth out any ripple and got an increase in voltage to 15 volts and on the 6 volt side to 7 volts. I also added an ne2 neon indicator for 120 volts and a momentary switch to discharge the capacitor. I find the charging abilities of this charger on a car battery to be better with the additional capacitor because the battery goes to full voltage. I use it to charge the batteries on both my portable solar carts when the sun is not out.</p>
<p>thank you for sharing what you did.</p>
Worked great.. This is exactly the schematic of lead acid battery desulfator having 16v output.. <br>I have further three or four querries.<br>1.how we can boost the amps?*<br>2. Increase 12v to 16v without changing the transformer?*<br>3. Add trip logic when battery reaches 13.8v?<br>*Add a boost switch to increase the amps to 7 and 16vdc.<br>Kindly guide me further.<br>Thanks a bunch
<p>I would like to be helpful, but your questions are beyond my knowledge. Perhaps someone else here can answer them.</p>
That's ok Mr. Phil. :) you have already helped enough.. Thanks again.
<p>hello Sir,</p><p>please i would like to have a detailed circuit diagram for a 12v/75ah car battery charger. thank you.</p>
From what I read, a battery should not be charged at a rate greater than one-fifth of its amp. hour rating. If you have a 75 amp. hour battery, the output of the charger should not be greater than 15 amps. There are a variety of circuits you can use. I have given a schematic in block form. If you do an Internet search, you will find many others. Some are more complicated and some are less complicated. The more complicated will require more expense and skill to assemble. But, they will also have more controls on the charger. A 15 amp. charger will require a transformer with an output of 15 amps. and a bridge rectifier capable of handling that much and more for a safety margin.
Thank You. will get back to you in case of any difficulty
Hello sir Pls help me out I want to build a 12v/70ah charger Pls how may I do that with transformer and diode
<p>hello sir</p><p> could this work for educational purpose as a source for car wirings circuits?</p><p>or even better buing one battery charger could make a wiring light of car with relay or flasher ( low light consumption) to work?</p>
Yes. The components I used are rated at only 3 amperes. The demands of devices you are demonstrating should not have a combined simultaneous current draw that exceeds the maximum output of your components. And, for the application you have in mind, I would add a 1,000 microfarad electrolytic capacitor at the output terminals of the bridge rectifier to smooth the current. That is good practice if you are using this as a power supply, not just as a battery charger.
Sir<br>Can I charge 12v battery with a 16v 4.5amp power supply ? It is a laptop chargers basicly.. I am using it to charge my battries.. will it damage my battries ?
I would want the voltage of the charger to be closer to the voltage of the battery. There may be a way to drop the voltage, but it might be more difficult and expensive than simply getting the right charger. Much depends on what batteries you are charging. A lead/acid battery would probably be more forgiving than a lithium-ion battery. Someone has done some Instructables on changing the output of switch mode power supplies. But, you would need to open the case of the laptop charger, find the correct resistor and change it to the correct value for the desired output.
Hi sir my name is Austine kauzeni from Tanzania i am a biginner to the electronics and i want to make an inverter than can also charge itself then i can also walkout with it anywhere and continue using without a problem of power drop . But kindly can you help me a circuits diagram?
<p>Hellow Sir,</p><p>I am making a 12 volt egg inkobeater and wants to run with 60 Amp wet battery, I want to make charger for battries need out put 65Amp please guide me While i have tried but that gives me just 7Amp</p>
In the end, the cost will be less if you can simply buy an automotive quick charger. Those have a high output like you need. I do not know where you would get all of the high current capacity parts needed to build your own. A 7 amp. Charger will eventually charge a battery that needs to put out 65 amps., but slowly.
<p>Hello I have a 12 volt solar charger that I want to drop to 6 volts. I see you are able to do this pretty easy. But I am just not seeing how you can drop the voltage from 12 to 6 volts could you better explain this please?</p>
The transformer I used has a center tap. The voltage between it and one of the outside taps is 6 volts. The voltage between two outside taps is 12 volts. Can you tap into your solar cell charger in a way that bypasses half of the cells?<br>
<p>hi sir</p><p>can this charger work with 12V 100Ah valve regulated battery? i bought an old battery from a junk shop nearby. i will use it as a backup power source when brownouts occur here in our place. i can't find removable caps on these batteries for adding water, its like a sealed type battery and only the two terminals are present on both ends.</p>
<p>I would think it could. You would want to avoid over-charging. Maybe you could run the charger through a timer. Have the timer come on for 30 or so minutes each day and see if that is enough to maintain a charge.</p>
<p>thank you very much sir, I'll try to make one. Uhmm.. any recommendation where i could add the timer in the circuit diagram you shown? I love electricals/electronics but I'm just a beginner. There are circuits I browsed on the net and this one you have is the simplest charger circuit I found, while the other ones have this IC parts that I was trying to analyze the works, you know.. kinda like catching a cheeta in the amazon!</p>
<p>ICs can do wonderful things, and are great, if they are really necessary. I do not understand much about most of them. I prefer to make things simple. If you wish to use a timer, add it to switch the AC mains. </p><p>There is a great story about Thomas Edison and Charles Stienmetz. Edison had a very large glass envelope for a special light bulb. He asked Steinmetz to calculate its internal volume. Steinmetz did a variety of calculations and took his results to Edison, but explained the uncertainty in his calculations. Edison asked him why he had not simply filled the glass envelope with water and measured how much water it contained. It is a lesson in simplicity.</p>
<p>that was also what I'm planning to do and cutting the AC mains is the safest way. thank you and I appreciate that much sir.</p>
You are very welcome.
Hi sir<br>First of all tanks for this useful circuit. <br>What's the rectifier's trade (industrial) name?
I am assuming you do not live in the United States. We have a grou of stores called Radio Shack. They sell electronic parts, including some parts. It is almost impossible to know what firm makes parts for Radio Shack. I would believe many are made in either China or other parts of the Pacific Rim.
I think thee may be a part number, but no maker's name.
Exactly. <br>There is no specific group here and we've to buy these pieces in different markets. However I meant the name written on the piece.<br>Thanks for the answer.
hi sir...i made a circuit that works on 6v DC. but i would like to know if this charger can be used to charge my 6 v battery without removing the battery from the holder and without damaging the circuit?
Congratulations on making a working charging circuit. You should be able to charge your battery without removing it. If the battery you are charging is part of a circuit with solid state electronics, you might want to protect against accidentally reversing the polarity. An easy way to do that would be to connect the charger with one type of male and female connector for the positive side and another type for the negative side. If the connectors are of different types, the wires will be impossible to connect in the wrong order.
<p>Hi sir, can I use 10A bridge rectifier(BR1010) with 12-0-12V transformer for charging 12V battery used for bikes.</p>
Yes, with one caution. The output current of the transformer should not be greater than 10 amperes or the bridge rectifier could be damaged.
<p>It would be a good idea to add a capacitor in parallel with the battery poles to smooth out the voltage ripple a bit. There are capacitors in almost every electronic device so salvaging one from a broken device shouldn't be so hard. The peaks of the ripple would induce electrolytic bubbling in the battery, unless regulated by a capacitor. Anyway, if no other components are available, this charger could save the day as it is.</p>
An electronics textbook I read a few years ago said batteries charge better if there is a little ripple, and that is why I did not suggest a capacitor across the output. I have temporarily added a capacitor to this charger when I wanted to use it as a power supply.
<p>Just did it, 3A trafo i bought for Rp50000 (about $4), and 4A Brectifier. Used it to charge my motorcycle accu which previously has dropped to 11.4v (holy-S!). For now it's still working just well, 30 mins has passed and the accu voltage raised to 11.7v. It's just a small accu (40Ah?) but i guess i have to wait for more hours.<br>My question is, what voltage do i have to stop charging? I think i'll stop the charging when it reaches 13v. I kinda afraid if it would blew up if i crank it to 14v.<br><br>*excuse me bout my english, not a native*</p>
Your English is much better than a lot of people who claim it as their first language. I have worked at learning a second language and know how difficult it is to use it well. <br><br>If your battery is sealed, it is difficult to know when it is fully charged. You could do some research on the Internet to see if you can find any data on your battery's voltage at a full charge. If your battery has removable caps so you can add water to the cells, any sign of boiling or of depletion of the fluid are indicators of over-charging. To be safe, I would charge until the battery has enough power to crank the engine. I expect the motorcycle has a charging circuit that will maintain the battery as you ride it. <br><br>If the battery does not take a charge, it may need to be replaced.<br><br>Congratulations on a job well done, <br><br>
About This Instructable
395,390views
250favorites
License:
Bio: I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying ... More »
More by Phil B:Easy Monitor for NordicTrack Skier Uses for Spent K-Cups Make a Conduit Bender
Add instructable to:
