3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Auto-loading Spaghetti Pen Gun
  • last photo ←
What you need:
- A standard pen
- Some tape
- A stick of dry spaghetti
- Some kind of sharp object (screwdriver possibly)
We used to make these as kids at school. :)
NOTE: Sorry some people seem to have gotten the wrong idea. I should of been more clear of
HOW IT WORKS:
Inside the pen is still the ink tube, the spring, and a little white cap the ink tube fits into.
when you push the ink stick in, it get stuck inside the cap. as you pull it back, it creates tension in the spring. When pull back the ink stick far enough the white cap pops off the ink stick and flies forward from the tension of the spring.
This strikes and shoots a small piece of spaghetti quite far.
Step 1Break pen in half
Break pen in half
Snap the pen where the coloured and transparent parts meet.
36 comments
Mar 24, 2011. 3:16 AMTHECHINABOY says:
this seems GREAT!!! But what pen did you use I dont have a pen that is like that.
Sep 6, 2009. 10:45 AMColonel88 says:
Sweet. Although I'd rather have a tube that you fill with BB's that spaghetti, I like the concept of this. Can you just tell me what type of pen you are using?.
Mar 11, 2007. 6:33 PMLemon says:
What if you used an electric motor as Aeshir said, to power a reciprocating arm (a piston) which rapidly pushes and pulls back the ink bit? Rapid-fire! If you wanted to, you could scale this up and actually make it out of wood or metal or something. Then attach rapid-fire and mount it on a camera tripod! Would this mechanism qualify as a gatling gun or is it a semi-automatic? :) Nice detailed instructable, I'm growing fonder of these office/classroom warfare things every day.
Oct 15, 2008. 5:47 PMookid says:
Wouldn't you have to slow the motor down a bit so that the spaghetti would have time to fall in place before it got shot out. if it was to fast nothing would come out the barrel.
Jul 24, 2007. 7:29 AMiwantacuracy says:
yeah your rubber band idea is good. it makes it even better.
Feb 29, 2008. 7:46 PMb3aux65 says:
spaggeta needler cool ill probably b working on that
Jan 19, 2008. 6:21 PMfosockingdude says:
cool
Jan 12, 2008. 8:11 PMPixel_Master says:
Could this be done with a mechanical pencil?
Dec 11, 2007. 9:36 PMtimmy_8911 says:
Can you put skewers in it???
Jan 26, 2007. 8:53 PMAeshir says:
AHAHA I just got a great idea. What if you made a case like a needler from Halo and made a bunch of these and put em in the needler? SPAGHETTI NEEDLER! MWHAHAHA!
Aug 18, 2007. 3:13 PMKnexfan says:
That would look cool, but did you forget? In Halo, the ammo on top of the needler was facing the other way. (Like this /) So you would just end up shooting yourself.
Aug 18, 2007. 3:57 PMAeshir says:
No...the Needler ammo faces away from the player.
See here
Aug 19, 2007. 7:22 AMKnexfan says:
Aug 19, 2007. 10:11 AMAeshir says:
The bottom of the needles point outward towards the barrel. The tops point toward the player. On this auto-loading spaghetti gun, it's the same thing. The long part of the barrel is not actually the barrel, it's where the pen goes.
Mar 17, 2007. 10:15 PMiKill says:
(removed by author or community request)
Aug 15, 2007. 10:02 AMbadrang4 says:
why dnt we just flag it?
Aug 15, 2007. 12:33 PMiKill says:
sorry... that was a really mean thing to say... i broke the be nice policy. sorry ilosn btw nice instructable
Jul 29, 2007. 10:00 AMrocketbat says:
constructive commenting? i dont think so!
Jul 24, 2007. 7:28 AMiwantacuracy says:
that is so good!!!!!
Jul 23, 2007. 9:36 PMdowngrade says:
You sir are a genius.
May 4, 2007. 2:09 PMVendigroth says:
i see how this works, now! the piston comes forwards, cracks of a little bit of spaghetti and shoots it out, as the piston goes back, the spaghetti drops down another notch and you're ready to fire again! neat!
Jul 1, 2007. 1:46 PMNeodudeman says:
omg that exactly how i felt when I read this. lol. i was like... "What...? It shoots a whole spaghetti strand backwards...?"
Mar 15, 2007. 2:38 PMcasvandegoor says:
you could use biby (or something like that) gun balls for ammo
Mar 15, 2007. 2:15 PMcasvandegoor says:
looks good, but about haw far does these things fly?
Mar 1, 2007. 5:28 PMpooboy says:
hey i made a sweet mod with an elastic band its awsome i load in like 5 pieces of pasta
Feb 5, 2007. 7:51 PM!Andrew_Modder! says:
Ahh! i was trying to make the SAME EXACT thing! But 4 some reason the 'ammo tube' wouldent stay in place, so it blocked the shots :-( i will try to rebuild one!
Jan 26, 2007. 9:50 PMAPeiceOfPoo says:
ha ha ha i made one of these once it was not exactly like this but it was similar
Jan 26, 2007. 9:28 PMAeshir says:
Now to add a motor and make it full automatic MWHAHAHA
Jan 25, 2007. 3:30 PMCalltaker says:
Just making sure I follow you correctly.... the only mode of propulsion for the pasta is you pushing against it with the pen guts. SOunds interesting. Onder if you could work a rubber band into the equation to get a stronger push. ~C
Jan 25, 2007. 5:13 PMVertigo666 says:
the stick breaking probably gives it most of the initial propulsion, but i agree- a rubber band would make it stronger
Jan 25, 2007. 8:42 PMGthing 2.0 says:
wow this looks cool but is it really as powerful as its seeem?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ILOSN
