Auto Transfer Switch
3,374
32
16
Posted
Introduction: Auto Transfer Switch
When power goes out in my home, this switch connects my
inverter to allow my sump pump to use inverted dc power automatically.
Parts
Relay k10p-11a15-120 (DPDT, 15A, 120VAC) JAMECO # 282247, $10.95
Deep plastic conduit box
Misc wire
Two male plugs
One female plug
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    1 Questions
    is your sump pump connected to 5 & 6? is there anything on 7 & 8? thanks
    See diagram for other connections
    5&6, sump pump
    3-7, jumper
    4-8, jumper
    thanks what about 1 & 2
    1 & 2?
    9 Comments
    Where does one get the plastic block to plug in the relay ?
    Check with JAMECO, I got as a set
    Thank you! It was really useful to me. Its crazy how some companies sell equipment to do this simple task for 100+ usd...
    Glad you can use, sometime just the simple things in life are the best
    I'm not sure if Home Depot has, I got mine on line (see description in parts list)
    Hey man wondering where you got the relay from? Could I pick it up at home depot?
    Thank you for your comments, there may be a lot of options here but this works for me
    http://www.directindustry.com/prod/heyco/liquid-tight-strain-relief-cable-glands-11746-1103353.html neither the box nor the "connectors" are water resistant. This device doesn't need to be. It should be placed above flood level.
    Nice to see you used proper water-resistant box & connectors. Instructable could use more detail and or a schematic to make it clearer. I've used this many times at remote sites for backup power switching, works great. Even if you don't have a 110vac relay you can just use an ac adaptor to match your relay voltage.
