Introduction: Automatic Cat Toy Shooter
Picture of Automatic Cat Toy Shooter
This an instructable on how to make an automatic ping pong ball shooter, for cats.
Materials:
Arduino
Computer
Tape
Hot Glue Gun
Card board
2 cardboard parts of toilet paper rolls
Plastic container at least 4 inches wide, 7 inches long, and 10 inches high
2 dc motors
1 180 degree servo
20 wires
2 pn2222 capacitors
2 1N4001 diodes
2 270 Ω Resistors
An arduino compatible ultrasonic sensor
Popsicle stick
Ping pong balls
2 2.5 inch wheels
Step 1: Top Holes
Picture of Top Holes
Cut 2 1.75 inch holes 2 inches apart on the top of your container. Then, using a glue gun, glue the two motors in the holes. You need to feed them through from the Bottom to the top. Make sure that they are securely inn the wholes when done gluing. The motors should look like the above picture of the prototype.
Step 2: Attaching Wheels
Picture of Attaching Wheels
Attach one wheel to the smaller part of the motor. Make sure that the wheel is centered and level on the motor before gluing. The wheels should look like they do in the picture above when done.
Step 3: Create the Curcuit
Picture of Create the Curcuit
Follow this circuit exactly
Step 4: Sensor Holes
Picture of Sensor Holes
Cut 2 holes to fit your ultrasonic sensor. I had to cut .75 inch holes, that were .5 inches apart
Step 5: Back Hole
Picture of Back Hole
Cut any sized hole in the bottom 3 inches of your container to be able to feed the arduino cable through. I cut mine at 1 inch
Step 6: Top Servo Hole
Picture of Top Servo Hole
My container came with a hole, but you need to cut a 2 inch hold in the top of your container to be able to feed the servo through.
Step 7: Put Arduino and Circuit in the Container
Picture of Put Arduino and Circuit in the Container
Put the arduino and circuit in the container so that the arduino ports are facing the back. Then put your ultra sonic sensor through the holes you cut.
Step 8: Feeder
Picture of Feeder
Cut a 1.5 inch high incision in the toilet paper roll, and cut around it so there is only 15% of the roll left on the back. Then hot glue it right in between the two wheels, so that the open hole part is facing the same way as the sensor.
Step 9: Feeder Step 2
Picture of Feeder Step 2
Cut a 1 inch incision upwards on the second toilet paper roll and cut around it so there is 30% left on the back. Then tape it onto the other roll that is already glued to the container. Make sure that the hole in the roll is facing the back of the container, and its on the bottom part of the roll.
Step 10: Servo Tower
Picture of Servo Tower
Create a 3 inch high, 1 inch wide, and 1 inch long cube tower with a 2 inch squared cover. Then tape the servo on top of it. Then tape a Popsicle stick to the servo so that it is in the hole in the top toilet paper roll. Then glue it to the back left corner of the container
Step 11: Plug Arduino in and Code
Picture of Plug Arduino in and Code
Plug in your arduino and upload this code.
const int trigPin = 9;
const int echoPin = 1;
servoPin = 11;
Servo Servo1;
long duration; int distance;
int motorPinA = 1;
int motorPinB = 2;
int onSpeed = 255;
int offSpeed = 0;
void setup() {
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
Serial.begin(9600);
pinMode(motorPinA, OUTPUT);
pinMode(motorPinB, OUTPUT);
Servo1.attach(servoPin); }
void loop() {
trigPin digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance= duration*0.034/2;
if (distance < 40) {
analogWrite(motorPinA, onSpeed);
analogWrite(motorPinB, onSpeed);
delay (5000);
Servo1.write(180);
delay (300);
Servo1.write(130);
analogWrite(motorPinA, offSpeed);
analogWrite(motorPinB, offSpeed); } }
Step 12: Enjoy
Picture of Enjoy
Enjoy the new cat toy
Here is a video of it
tomatoskins (author)2017-11-06
What a cool project! How long did it take you to develop?
534867 (author)tomatoskins2017-11-06
it took me about 1 week, one hour a day! I will add a video of it working tommorow
About This Instructable
980views
17favorites
License:
More by 534867:Automatic Cat Toy Shooter
Add instructable to:
