Remove these ads by
Signing UpStep 1How to do it
All you need to do is check occasionally to see if the container needs a refill.
No need to place the water above the level of the pot the water will climbe up a reasonable height to get into the pot.
Enjoy your holiday season!
- details a finished project with instruction (not just links to instructions)
- has clear images that you took of your project (web-found clip-art is not acceptable)
- uses proper spelling and grammar
- contains appropriate cautions or safety considerations
- does not violate someone else's copyright
- does not violate the Instructables terms of service
- is typically written about something you are very passionate about and want to share.
If this is a comment, a question, a small tip, or something that cannot truly be a finish project, please post it as a forum topic. If you are looking to start a collaboration, post a topic in the forums. Look here for tips on writing a great Instructable.
http://www.instructables.com/id/ELHMNOA69REUF10WM7/
So, it has been unpublished. Please do not republish until it has been corrected. When you republish, if everything is fixed, I'll remove this note. Multiple attempts to republish without correction will result in deletion.
