In this project, I designed a nightlight that automatically dims and turns itself off. A lot of people find it difficult to fall asleep when they suddenly transition from a brightly lit room to complete darkness. A dim source of light such as a nightlight helps them to adjust to a lower brightness and fall asleep more easily. But the down side of most nightlights is that they waste electricity because they are on all night when you really only need them to be on while you are falling asleep. So I designed a nightlight that will automatically dim and turn itself off after a certain period of time that is set by the user
Remove these ads by
Signing UpStep 1Materials
Jumper wires
Printed circuit board
IC1: 741 OP AMP
IC2: 741 OP AMP
Terminal Connectors
R1: 1MΩ
R2: 5kΩ variable
R3: 2.2kΩ
R4: 3.3MΩ
C1: 2200µF 10V
C2: 2200µF 10V
D1: 1N4001
D2: D3: D4: 3.5V LED
S1: SPST latching switch
S2: momentary switch
Plastic project box
T1: 6V 400mA DC power supply
It may also be helpful to have some glue and heat shrink tubing.
Tools:
Drill
Soldering Iron
Wire cutters
Pliers
Screw driver
As much space as it provides, I would look at making two more lights on the same pattern, but with differently colored LEDs. Putting them all on different time differentials with the variable resistor would make an impressive light show in the room as they all faded away.
