Automatic Garden Watering System BY Arduino, LCD, Buttons, EEPROM, Solenoid Valve, Motor and Underground Sprinkler
Published
Introduction: Automatic Garden Watering System BY Arduino, LCD, Buttons, EEPROM, Solenoid Valve, Motor and Underground Sprinkler
About: I love electronics .Arduino automation
Now we are making automatic watering plant
I use .5 KW motor which can operate only one sprinkler at a time
so i use this method
which give me positive result
Step 1: Hardware Required
for automation you can add different things i choose Solinoid valve
In this project you will control solidnoid by mobile .
WE will also make it Automatic by timing
if mobile is not present you can also operate with keypad
I also add lcd in the project to see the the present status of Solidnoid switches
hardware required in this project
Android Mobile jumper cables
16 * 2 LCD display
HC-06 Bluetooth Module
Arduino uno or MEGA
Bread Board
10k ohm varible for LCD
Relay Module
For making own relay
Module Relay
Transister Resisters
PCB board
Step 2: Software Required
https://play.google.com/store/apps/details?id=com....
Download this app for automation
it can control 8 relay at a time
Its also have a timer.
To program on arduino use Arduino IDE which is available on
https://www.arduino.cc/en/Main/Software
Step 3: Piping Design
Attach all the solinoid with the pipe in parallel
and attach underground sprinkle in series with solidnoid valve
This digram will help you in pipeing
Step 4: Loading Program Witharduino and Relay Module
in this we only use relay module and arduino
I have 15 minin you can also change
in arduino 1 second is equal to 1000
1 min is equal to 60000
change it according to requirement
<p>int timer = 900000;          <br>int solid[] = { A0, A1, A2, A3 };
int pinCount = 4;           </p><p>void setup() {
  for (int thisPin = 0; thisPin < pinCount; thisPin++) {
    pinMode(solid[thisPin], OUTPUT);
  }</p><p>for (int thisPin = 0; thisPin < pinCount; thisPin++) {
    digitalWrite(solid[thisPin], HIGH);
    delay(timer);
    digitalWrite(solid[thisPin], LOW);</p><p>  }
void loop() {
 }</p>
Step 5: Now Adding Start Botton in Arduino
when you press button machine will start at that time
Change the timer setting according to your requirement
1min is equal to 60000 in arduino
change setting according to this
<p>[code]<br>int timer = 5000;
int pinCount = 4;
int sw[]={6};
void setup() {
  }</p><p>
  pinMode(sw[0], INPUT);
  digitalWrite(sw[0], HIGH);
 }</p><p>void loop() {
  if(digitalRead(sw[0]) == LOW) {
    delay(timer);
  }</p><p>[/code]</p>
Step 6: Adding LCD in the Project
NOw i add lcd in the project to see the status of solenoid valve
[code]
#include
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); int timer = 1000; int solid[] = { A0, A1, A2, A3 }; int pinCount = 4; int sw[]={6};
void setup() { lcd.begin(16, 2); for (int thisPin = 0; thisPin < pinCount; thisPin++) { pinMode(solid[thisPin], OUTPUT); }
pinMode(sw[0], INPUT); digitalWrite(sw[0], HIGH); }
void loop() { lcd.setCursor(0, 0); lcd.print("M1 OFF"); lcd.setCursor(8, 0); lcd.print("M2 OFF"); lcd.setCursor(0, 1); lcd.print("M3 OFF"); lcd.setCursor(8, 1); lcd.print("M4 OFF"); if(digitalRead(sw[0]) == LOW) { lcd.setCursor(0, 0); lcd.print("M1 ON"); digitalWrite(solid[0], HIGH); delay(timer); digitalWrite(solid[0], LOW); lcd.setCursor(0, 0); lcd.print("M1 OFF"); lcd.setCursor(8, 0); lcd.print("M2 ON"); digitalWrite(solid[1], HIGH); delay(timer); digitalWrite(solid[1], LOW); lcd.setCursor(8, 0); lcd.print("M2 OFF"); lcd.setCursor(0, 1); lcd.print("M3 ON"); digitalWrite(solid[2], HIGH); delay(timer); digitalWrite(solid[2], LOW); lcd.setCursor(0, 1); lcd.print("M3 OFF"); lcd.setCursor(8, 1); lcd.print("M4 ON"); digitalWrite(solid[3], HIGH); delay(timer); digitalWrite(solid[3], LOW); lcd.setCursor(8, 1); lcd.print("M4 OFF"); } }
[/code]
Step 7: Set Time by Using Two Button and EEPROM
Now i add two button to set time
now you can set time by button LCD is present
one button is for time up and is for time down
#include  <LiquidCrystal.h>
#include <EEPROM.h>
int pinCount = 4;
int sw[]={6};
int st = EEPROM.read(1);
int swt[] ={7,8};
void setup() {
lcd.begin(16, 2);
  }</p><p> pinMode(sw[0], INPUT);
  pinMode(swt[0], INPUT);
  digitalWrite(swt[0], HIGH);
   pinMode(swt[1], INPUT);
  digitalWrite(swt[1], HIGH);
void loop() {
  int timer = EEPROM.read(1) * 60000;
    lcd.print("SET Time");
    lcd.print(st);
    lcd.setCursor(4, 1);
    lcd.print("MINUTES");
    if(digitalRead(swt[0]) == LOW) {
      EEPROM.write(1, st++);
      delay(1000);
      lcd.clear();
    if(digitalRead(swt[1]) == LOW) {
      EEPROM.write(1, st--);
      delay(1000);
      lcd.clear();
    lcd.clear();
    lcd.print("M1  ON");
    delay(timer);
    lcd.print("M2  ON");
    delay(timer);
    lcd.print("M3  ON");
    delay(timer);
    lcd.print("M4  ON");
    delay(timer);
    lcd.clear();
Step 8: Troubleshooting and Feedback
IF any problem arises contact me through inbox
Kindly give me feed back i like when some one give feedback
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    11 Comments
    Hi!
    Respekt for this project!!! I intereseting and i trying make this projekt.
    I have one question for you, please help me:
    When i copy the last commands (set time commands) to the ardunio program software, i have one fault: exit status 1: Can't translate for Ardunio/Genuino board.
    What's cause the problem?
    Thank you very much and best regards:
    Zámbó János
    in lcd library i use "," instead of "."
    i have corrected kindly check
    Thanks for feed back
    is this possible that i will use 12v pump because my source is 12v from solar energy. for farmers doesnt have electricity
    Kenny, certainly it is possible to use a 12 VDC pump, but not with those sprinklers. I'm running a similar project with Arduino, but I use drip pipes which require low pressure, thus allowing me to use a 12 VDC pump which provides low pressure.
    Yes possible.
    Relays are attached
    You can use 12 to 220 v pump as you need
    nice instructable, keep up the good work ;)
    thanks a lot!!! good work, I was looking long time for this!!!
    Greetings
    Thanks for feedback
    I will more try to upgrade
