Automatic Guitar Tuner
13,363
30
35
Published
Introduction: Automatic Guitar Tuner
Two things that I really like to do are: play guitar and tinker with my Arduino. I was very interested at the thought of this project, so I decided to do it. I am new to programming, so this was a real challenge to me!
This machine works with an electric guitar. It takes the electrical signal transmitted from the guitar and analyzes the code. It all starts with the Op Amp circuit. The circuit itself and the code was designed by amandaghassaei, and I want to thank her for helping me get a running start on my project.
Here is the list of processes in a nutshell:
1. The string is picked, and the electrical signal is sent through the stereo cable, which carries the sound waves.
2. The female stereo adapter receives the sound waves and puts it into the Op Amp circuit.
3. The Op Amp circuit takes the sound waves and increases the amplitude, so that the Arduino can read it easily. It then sends the signal into the Arduino to be sampled.
4. The Arduino samples the frequency of the sound waves, and records it on the serial port so the user can see.
5. The Arduino looks at which direction the 6-way rotary switch is in, so that it can determine which string it is tuning.
6. The position of the rotary switch determines what the desired frequency is for the string to be at (with a margin of error of 2Hz)
7. If the String is not in tune, then the motor moves accordingly.
8. This process repeats until the string is tuned, then the user moves on to the next string.
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    35 Comments
    Can I get Schematic please?
    I am currently working on the schematic. I will post it as soon as possible. As far as the audio input circuit, go to amandaghassaei's arduino audio input instructable. Thank you for your interest!
    can i know what the component that u use in this project?..
    The below code compiled
    #include <Servo.h>
    Servo Servo1; //declaration of servo object
    int angleStill = 90; //stores servo position
    int angle = 90; //stores servo position
    int trim = 0; //trim adjustment to zero position
    int servoPin = 8; //Arduino pin assigned to servo
    int clockwisespeed = 120; //the speed to go in the clockwise direction
    int countclockwisespeed = 60; //the speed to go in the counter clockwise direction
    boolean clipping = 0; //clipping indicator variables
    //data storage variables
    byte newData = 0;
    byte prevData = 0;
    unsigned int time = 0;//keeps time and sends values to store in timer[] occasionally
    int timer[10];//sstorage for timing of events
    int slope[10];//storage fro slope of events
    unsigned int totalTimer;//used to calculate period
    unsigned int period;//storage for period of wave
    byte index = 0;//current storage index
    float frequency;//storage for frequency calculations
    int maxSlope = 0;//used to calculate max slope as trigger point
    int newSlope;//storage for incoming slope data
    int minfreq; //it will be changed according to its string
    int maxfreq; //it will be hanged according to to its string
    int basefreq = 0; //define baseline noise to ignore any frequency less than this value
    //int highstring;//says if you are tuning high string or not
    //variables for decided whether you have a match
    byte noMatch = 0;//counts how many non-matches you've received to reset variables if it's been too long
    byte slopeTol = 3;//slope tolerance- adjust this if you need
    int timerTol = 10;//timer tolerance- adjust this if you need
    int notenum = 0; //set the guitar string number I want to tune
    int notenumPrior = 0; //holds the previously selected guitar string
    //all Arduino programs must have a setup routine
    //Starts Setup routine
    void setup(){
    Serial.begin(9600); //begins sampling the serial port for monitoring purposes
    pinMode(13, OUTPUT); //clipping indicator
    pinMode(12, OUTPUT); //wave period indicator
    pinMode(11, OUTPUT); //freq too low
    pinMode(10, OUTPUT); //freq spot on
    pinMode(9, OUTPUT); //freq too high
    //sets all three pitch indicator lights off
    digitalWrite(11, LOW);
    digitalWrite(10, LOW);
    digitalWrite(9, LOW);
    pinMode(7, INPUT);// different paths from dip switch indicating the notenum value (output)
    pinMode(2, INPUT);
    pinMode(3, INPUT);
    pinMode(4, INPUT);
    pinMode(5, INPUT);
    pinMode(6, INPUT);
    digitalWrite(7, HIGH);// making sure the input pins are set high, so when pressed they will be on low
    digitalWrite(2, HIGH);
    digitalWrite(3, HIGH);
    digitalWrite(4, HIGH);
    digitalWrite(5, HIGH);
    digitalWrite(6, HIGH);
    Servo1.attach(servoPin); //attaches servo on pin x to servo object
    //ADC - Handle Analog to Digital Conversion of Guitar Signal
    cli(); //disables interrupts
    //set up continuous sampling of analog pin 0 at 38.5kHz
    //clear ADCSRA and ADCSRB registers
    ADCSRA = 0;
    ADCSRB = 0;
    ADMUX |= (1 << REFS0); //set reference voltage
    ADMUX |= (1 << ADLAR); //left align the ADC value- so we can read highest 8 bits from ADCH register only
    ADCSRA |= (1 << ADPS2) | (1 << ADPS0); //set ADC clock with 32 prescaler- 16mHz/32=500kHz
    ADCSRA |= (1 << ADATE); //enabble auto trigger
    ADCSRA |= (1 << ADIE); //enable interrupts when measurement complete
    ADCSRA |= (1 << ADEN); //enable ADC
    ADCSRA |= (1 << ADSC); //start ADC measurements
    sei();//enable interrupts
    void reset()
    {//clea out some variables
    index = 0;//reset index
    noMatch = 0;//reset match couner
    maxSlope = 0;//reset slope
    //Launch Continuous Interupt Service Routine (ISR) for Sampling Analog to Digital Conversion of Guitar Audio Input
    ISR(ADC_vect)
    {//when new ADC value ready
    PORTB &= B11101111;//set pin 12 low
    prevData = newData;//store previous value
    newData = ADCH;//get value from A0
    if (prevData < 127 && newData >=127){//if increasing and crossing midpoint
    newSlope = newData - prevData;//calculate slope
    if (abs(newSlope-maxSlope)) //record new data and reset time
    slope[index] = newSlope;
    timer[index] = time;
    time = 0;
    if (index == 0)
    {//new max slope just reset
    PORTB |= B00010000;//set pin 12 high
    noMatch = 0;
    index++;//increment index
    else if ( abs(timer[0]-timer[index]) ) //sum timer values
    totalTimer = 0 ;
    for (byte i=0;i= totalTimer+=timer[i];)
    period = totalTimer;//set period
    //reset new zero index values to compare with
    timer[0] = timer[index];
    slope[0] = slope[index];
    index = 1;//set index to 1
    noMatch = 0;
    else{//crossing midpoint but not match
    if (index > 9)
    reset();
    else if (newSlope>maxSlope)
    {//if new slope is much larger than max slope
    maxSlope = newSlope;
    time = 0;//reset clock
    noMatch = 0;
    else{ //slope not steep enough
    noMatch++;//increment no match counter
    if (noMatch>9){
    reset();
    if (newData == 0 || newData == 1023){//if clipping
    PORTB |= B00100000;//set pin 13 high- turn on clipping indicator led
    clipping = 1;//currently clipping
    time++;//increment timer at rate of 38.5kHz
    void checkClipping(){//manage clipping indicator LED
    if (clipping){//if currently clipping
    PORTB &= B11011111;//turn off clipping indicator led
    clipping = 0;
    //Start of Main Arduino Loop
    void loop() // loop
    //highstring = 0;
    frequency = 38462/float(period); //calculate frequency timer rate/period
    // added for debugging and visualizing data
    Serial.print(frequency);
    Serial.println(" hz");
    Serial.println(" ");
    Serial.println("string picked: ");
    Serial.print(notenum);
    notenum_val(); //call function to determine value of note/string we want to tune
    freq_range_identify(); //set frequency threshold ranges for string previously selected
    checkClipping(); //frequency determining and led indicator loop
    set_indicator_lights(); //checks value of current frequency and lights correct indicator light. Then moves servo accordingly
    //Serial.println(angle);
    move_motor(); //move tuning servo motor
    //delay(1000); //turn on to control debouncing
    notenumPrior = notenum;
    } //end of main loop
    //Determine String selected from rotary switch and voltage values on designated arduino pins
    void notenum_val()
    int val_1 = digitalRead(2); //read the value of rotary switch pins
    int val_2 = digitalRead(3);
    int val_3 = digitalRead(4);
    int val_4 = digitalRead(5);
    int val_5 = digitalRead(6);
    int val_6 = digitalRead(7);
    if (val_1 == LOW && val_2 == HIGH && val_3 == HIGH && val_4 == HIGH && val_5 == HIGH && val_6 == HIGH) //switch set on pressed, then notenum = 1
    if (notenumPrior != 1)
    delay(5000);
    notenum = 1;
    else
    notenum = 1;
    else if (val_1 == HIGH && val_2 == LOW && val_3 == HIGH && val_4 == HIGH && val_5 == HIGH && val_6 == HIGH) //Switch 3 pressed, noenum = 2
    if (notenumPrior != 2 )
    delay(5000);
    notenum = 2;
    else
    notenum = 2;
    else if (val_1 == HIGH && val_2 == HIGH && val_3 == LOW && val_4 == HIGH && val_5 == HIGH && val_6 == HIGH) //switch 4 pressed, notenum = 3
    if (notenumPrior != 3)
    delay(5000);
    notenum = 3;
    else
    notenum = 3;
    else if (val_1 == HIGH && val_2 == HIGH && val_3 == HIGH && val_4 == LOW && val_5 == HIGH && val_6 == HIGH) //switch 5 pressed, notenum = 4
    if (notenumPrior != 4)
    delay(5000);
    notenum = 4;
    else
    notenum = 4;
    else if (val_1 == HIGH && val_2 == HIGH && val_3 == HIGH && val_4 == HIGH && val_5 == LOW && val_6 == HIGH) //switch 6 pressed, notenum = 5
    if (notenumPrior != 5)
    delay(5000);
    notenum = 5;
    else
    notenum = 5;
    else if (val_1 == HIGH && val_2 == HIGH && val_3 == HIGH && val_4 == HIGH && val_5 == HIGH && val_6 == LOW) //switch 7 pressed, notenum = 6
    if (notenumPrior != 6)
    delay(5000);
    notenum = 6;
    else
    notenum = 6;
    else
    notenum == 0;
    // Sets the flat, sharp and spot on frequency thresholds depending on the string we're trying to tune
    void freq_range_identify()
    switch (notenum)
    case 1://desired frequency=80-84 -- ideal value is 82
    minfreq = 80;
    maxfreq = 84;
    break;
    case 2://desired frequency between 108-112 ideal=110
    minfreq = 108;
    maxfreq = 112;
    break;
    case 3://desired frequency between 145-149 ideal= 147
    minfreq = 145;
    maxfreq = 149;
    break;
    case 4://desired frequency between 194-198 ideal=196
    minfreq = 194;
    maxfreq = 198;
    break;
    case 5://desired frequency= 245-249 -- ideal value is 247
    minfreq = 245;
    maxfreq = 249;
    break;
    case 6: //desired frequency between 328-332 ideal=330
    minfreq = 328;
    maxfreq = 332;
    //highstring = 1;//stating high string is one being tuned
    break;
    //Sets the 3 appropriate pitch indicator lights and sets the direction and speed of the tuning motor
    void set_indicator_lights()
    // if (highstring = 1)
    // checkfreq();
    if (frequency <= basefreq)
    digitalWrite (11, LOW);
    digitalWrite (10, LOW);
    digitalWrite (9, LOW);
    angle = 90;
    else if (frequency < minfreq && frequency > basefreq)
    digitalWrite (11, HIGH);
    angle = countclockwisespeed;
    else if (frequency > maxfreq)
    digitalWrite (9, HIGH);
    angle = clockwisespeed;
    else
    digitalWrite (10, HIGH);
    angle = 90;
    delay(1000);
    checkfreq();
    void checkfreq()
    Serial.println("doublecheck");
    angle = 90;
    else
    angle = 90;
    Serial.println("String is tuned! Please move on!");
    delay(5000);
    //Turns the tuning motor appropriately
    void move_motor()
    Servo1.write(angle+trim);
    delay(50);
    Servo1.write(angleStill+trim);
    Last time I checked it compiled correctly and worked with the circuit. I will work on cleaning up the code and making a schematic so you can hopefully make your own!
    what kind of microphone did you use?
    Can anyone link Amanda's stuff on here for me? I'm having trouble finding it
    The low E on a guitar is 82.41 Hz. If you go low by 2 Hz (your margin of error) then you end up about halfway to Eb. That quarter tone is *very* noticeable.
    I'm not saying this to discourage you, or discount your work. On the contrary, I think this is a fantastic idea and great work. I just want to see it get even better!
    Nice!! What kind of servo motor you have use? and can you get schematics?
    Did you ever find out what kind of servo is being used?
    no but i used AAS-750MG servo. it has enought torque.
    Has anyone been able to replicate this, and if so, how did you wire the 2 pol 6 way switch with the arduino?
    wow !!! awesome
    Owhhh..hmmm, let say i do exactly your project like on the picture and take your code. Will the project works? Or i need to refer to amandaghassaei's project too?
    The audio input and frequency detection I used are identical to amandaghassaei's. I reccommend you follow her instructables to make them, simply because I am working on cleaning up the code and making a schematic so you can make your own. Thanks.
    I will get on it. Sorry I have been absent, I have been rather busy recently. I will do whatever I can to help! I do not have a schematic, but I will make one. Thanks for your interest!
    can i get a schematic pls?
