Introduction: Automatic Halloween Candy Dispenser
When trick-or-treaters show up at my house they can text, call, or tweet a code displayed on an LCD screen to get their Halloween candy. They can also push the Big Red button.
Once the candy request is made a few "special" effects are triggered by X10 modules. A low laying fog machine is activated and lights turn on while the candy shoots down from my front deck on the second floor.
* Update. Now with video!
Step 1: Materials
- Plastic Bucket
- 3 in. x 60 in. Round Pipe
- 2 Futaba S3003 Servos
- 1 Old CD
- Nuts and bolts
- Plastic Project Enclosure
- Big Dome Push Button
- 16x2 Serial LCD Display
- Snap-In Category 5e RJ-45 Jack
- Size M Panel-mount Coaxial DC Power Jack
- 12 V DC transformer
- Cat 5 Cable
- Aluminum Project Enclosure
- Arduino Duemilanove
- Adafruit Protoshield
- XBee adapter kit
- x10 Firecracker CM17A
- x10 Transeiver
- 1 100k resistor
- X10 Appliance module
- 125VAC/10A DPDT Plug-In Relay (as a switch combined with x10)
Styrofoam cooler and dryer hose and Ice to create low laying fog.
(Check my last year Halloween project https://www.instructables.com/id/Halloween-Dropping-Spider/ for more info).
- Incandescent black light, strobe light, black light bulbs.
Step 2: Candy Dispenser
The ventilation pipe comes in a "U" shape, so I made a "U" shaped cut in the bottom center of the bucket. Notice I did't cut the whole "U", instead I left a piece of plastic in the middle to hold the servo motor that rotates the CD.
After I inserted the ventilation pipe I did a few cuts to allow me to expand the pipe into a sheet form. I used a couple screws and bolts to keep the sheet attached to the bucket. The rest of the space was covered by the mighty duck tape.
I cut the CD to allow the candy flow when rotated. Also I duck taped a continuous servo inside to function as a "shaker."
Step 3: Control Box
I really like the use of CAT 5 cable to make things more modular.
Step 4: Main Box
The main loop is waiting for either a physical push of the big red button or to receive a remote serial message. The attached XBee module communicates with another XBee module connected to the ioBridge IO-204 module serial board.
These are the digital I/O pins configuration:
XBee Module (with adafruit XBee kit)
- Pin 13 - TX
- Pin 12 - RX
- Gnd and 5v
- Pin 8 - Button NO(normally open) + GND + 100K.
- 5v - COM
Servo 1 (continuous rotating servo used for shaking)
- Pin 7 - Data
- Gnd and 5v
Servo 2 (used to rotate the CD)
- Pin 6 - Data
- Gnd and 5v
X10 C17A (x10 devices controller)
- Pin 3 - DTR line for C17A - DB9 pin 4
- Pin 2 - RTS line for C17A - DB9 pin 7
- Gnd - DB9 pin 5
ioBridge 16x2 serial LCD display
- Pin 1 - LCD Data pin
- Gnd and 5v
Step 5: Code Generator
Instead, I created a REST web service using of course my favorite web development tool, Oracle Application Express http://apex.oracle.com/ , to make sure a unique and random code was generated each time candy drop request was made from text, call or Twitter.
The REST application is really simple and I recognize it can also be created using any other technologies such as LAMP or even a GCI, or Perl application.
Application Objects:
- 1 Table (ID,CODE,SELECTED)
- 1 Numerical Sequence to generate primary key (ID)
- 1 Trigger before insert record that will get the ID value and append a random number to the CODE column
- 1 public procedure to retrieve the code (where selected = 1)
- 1 public procedure to update the code once is used and generate a new one.
http:/my.apexserver.com/pls/apex/getcode
http:/my.apexserver.com/pls/apex/updatecode?code=XXXX
*If you would like to implement something with a static file instead, I would recommend using http://www.random.org/clients/http/ to get a random number and store it in file, memory, or even the arduino itself.
Step 6: IoBridge Setup
There are two main functions that the ioBridge was used for:
- Request current code
I do a GET call from the arduino to retrieve the current code from my Code Generator service using ioBridge Serial Web Services API.
Arduino code:
mySerial.println("[[[get|http:/my.apexserver.com/pls/apex/getcode]]]");
- Start candy dropping sequence by text, call or tweet.
An ioBridge widget will send a start character via serial message and the candy dropping sequence will start. This widget can be called using the ioBridge Static Widget API.
This URL is called by Twilio and by my custom Twitter alert script.
http://www.iobridge.com/widgets/static/id=[widgetID]
- ioBridge Serial Board
- TX - RX XBee
- RX - TX XBee
- GND and 5v
Step 7: Twilio Setup
The voice application answers the phone, plays an intro sound file and asks for the code followed by the # sign. If a code is detected Twilio will do a "GET" action to a PHP file that will lookup the current code from my Code Generator Web Service. If it matches it will call the ioBridge static widget URL and candy will be dispensed.
The SMS application has almost the same PHP code except this time instead of looking for the digits dialed it will look for body of the SMS message.
Check the attached XML and PHP files that generate the TwiML XML.
All in all Twilio is a winner and I have plenty of other ideas for the future.
Step 8: Twitter Setup
Twurl is almost like curl but for Twitter. I did some ugly parsing of the twitter RSS feed to retrieve the tweet sender, but it works!
Here is my bash script
#!/bin/bash
mycode=`curl --silent http:/my.apexserver.com/pls/apex/getcode`
twitter=`twurl /1/statuses/mentions.rss | grep "@tweetfortreat $mycode" | cut -d ':' -f1 | tail -n 1 | cut -d '>' -f2`
echo $mycode $twitter
if [ -n "$twitter" ]; then
iobridge=`curl --silent http://www.iobridge.com/widgets/static/id=[widgetID]`
newkey=`curl --silent -d "code=$mycode" http:/my.apexserver.com/pls/apex/updatecode`
update=`twurl -d "status=@$twitter The code $mycode is correct. Happy Halloween!" /1/statuses/update.xml`
echo $newkey $iobridge
fi
Crontab will only allow you to execute a script every minute and I think is fine for now. Alternatively a while loop could be used instead.
Here is my crontab entry
*/1 * * * * /script_location/HalloweenCandy.sh > /dev/null 2>&1
Step 9: Conclusion and Alternatives
I hope to see more iterations of the Automatic Halloween Candy Dispenser next year. Please make sure you share all your ideas/improvements in the comments section.
Happy Halloween!
