3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Automatic Incense snuffer, make your incense last longer.
A simple incense snuffer to fit a box type burner. Makes the Nag Champa last longer.
Sometimes when you just want to freshen up you room you light an incense stick meaning to let it burn for a few min and then put it out, you either forget and find that the room is now lue with smoke. here is a quick and simple way of making a snuffer that to can move along the tray of you burner so that only the exact amount you want will burn.
All you need is a short cutting of 15mm copper pipe. in my case 30mm long.
the only tool used is a file, or grinder / sander even wet and dry sandpaper would do and a pair of pliers.
I discovered this nice little tip when i can home from work at the hardware store with a small cutting of 15mm copper pipe in my pocket, a customer had handed it to me and asked for a pipe fitting to fit that and I he never took it back. Later that evening i went to light an incense stick and fished the pipe out of my pocket when looking for my lighter and the idea was born mainly because it was an exact fit to the burner i had.
Its not much but it works, a box of Nag Champa does fro ages now.
Thanks for looking, I hope you like this idea.
Andy.
Step 1Cut some copper pipe.
  • last photo ←
First cut the copper pipe until it fits into the tray of your incense burner box.
Use the pliers to squeeze a flat part along the length of the pipe. this will make the pipe sit better in the tray when finished.
Once to have the flat made you need to grind away some of the top of the snuffer to allow the lid of the box to close.
once the lid can close over the snuffer without catching its job done, give the pipe a rub with wire wool or a brillo pad to shine it up and remove any rough edges or burrs from cutting.
6 comments
May 6, 2011. 9:01 PMRaydoom says:
what also works is rapping a stripp of al foil around the stick to where you want to burn , much cheaper too
Jul 13, 2010. 6:51 PMchndt2008 says:
نم™‰
Jul 15, 2010. 10:33 AMDillard421 says:
Really Neat Idea!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
117
Author:Dr Qui
Currently under no fixed agenda, just going with the flow. All projects are designed to be low cost and to be a simple as possible using recycled and re-purposed materials. Andy.
