Automatic Light Switch
I was bored of turning the light on myself, so I built this! It's made from the LEGO NXT Mindstorms. It works by attaching a two long pieces to a motor. You also must have it stable so I lifted it up and taped it down. Finally attach a cord from the motor to the Mindstorms main unit. By the way, I programed it to turn on and off when I push the button, and I also programed it listen for my voice and turn on and off. Sorry some of the pictures are side-ways or bad quality.
21 comments
Jun 10, 2010. 8:58 PMjosh804 says:
Wow. It would be cool if you get a sound sensor and just say lights off! and it would turn off.
Jul 11, 2011. 11:18 PMbomb voyajue says:
that would be epic :D
Mar 29, 2009. 10:26 AMakashmash says:
i made something likethis a long time ago. i used the ultrasonic sensor so it turned on when i walked up to my nxt'ised automatic door. my door used to open with anotther ultrasonic sensor but it wasnt that good and it smashed because it got caught on the door stopper
Mar 12, 2009. 2:54 PMWafflicious says:
are you using the ultrasonic sensor for the automatic part?
Oct 4, 2008. 1:23 PMberky93 says:
so its like a lego clapper! cool! you should post more details on how you built it though, even though its a really simple design
Oct 4, 2008. 6:00 PMdsman195276 says:
take it apart and take pictures as you go. then put them up in reverse and build it again. i do it all the time with knex, i don't know what you will do about the tape though...
Dec 29, 2008. 10:00 AMpobturtle says:
It doesn't take that long to take it apart. There isn't even that much pieces. It would also be very helpful to other people.
Dec 15, 2008. 9:00 AMemdarcher says:
I made one of these at home a long time ago way before you made this instructable.
Oct 28, 2008. 8:49 PMPadlock says:
I made one of these directly connected to the Light Switch (actually, a fan switch.). I then set up a home-brew PIR sensor to detect if anyone was in the room, turning on the fan when it returned positive.
Oct 28, 2008. 8:51 PMPadlock says:
It works a lot better if you take longer outlet cover screws and add them through one of the holes in a beam, then build the entire structure off of that.
Oct 20, 2008. 9:21 PMacer73 says:
Let me get this you made a device that can turn on and off a light by you pressing a button. Its just that it seems really redundant when your pressing a button to flip a switch. Cut out the middle man and just use your own hand.
Oct 4, 2008. 1:51 PMagdollison says:
i do not see any rhyme or reason to it
Oct 5, 2008. 5:18 PMshooby says:
Same here. Maybe there is a good reason for building it. How could you be bored with turning a light on and off. Flip a switch or push a button, they're just as boring! Besides, you probably spend less than 10 seconds a day turning lights on and off. ANyways, if you want to make this more worthwhile, install a dimmer, and have that controlled with your LEGO thing.
Oct 4, 2008. 6:01 PMdsman195276 says:
does it need one? more then half if not all of the instructables ever posted have no real reason or are not truly needed.
Jul 26, 2010. 12:05 AMTheKnerd says:
Some people just get bored and need something to do and they make stuff and post it here.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:downhilldman
I am sooooooooooooo awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
