There are a few steps, and depending on how many walls away door is, construction will differ. In this instructable, you will learn how to make an automatic door closer, controlled by pulleys . Almost every Item Listed is from home depot. I did not show pictures of the molleys and dry wall screws, because that is all preferance based.
Remove these ads by
Signing UpStep 1The Door closer
1. Drill the four holes on opposing corners.
2. Remove all copper staples
3. Unhinge the bottom where the arm of the rat trap holds the springs.
4. Remove and discard the safe guard holder where you put the cheese.
Picture 2:
1. Cut the broom stick about 2 feet away from the handle. It depends where you put the rat trap, but it shouldnt be more than 2 feet.
2. Dremmel out enough space to place the toy car wheel( reduces friction when riding on the door.
3. Drill an axis for the whell, where the arrows indicate. You want to make sure there is enough room left for the wheel to spin.
4. place the wheel in the handle, and slide a nail through the axis holes you drilled. If the wheel wobbles when spun,take the nail out, and place a staw on both sides of the wheel for bearing. Cut the end of the nail off with wire cutters. Your finished product should look like Picture 3.
33
comments
Add Comment
Romado12187 (author)
says:
says:
says:
says:
says:
says:
says:
says:
lemonie
says:
says:
ll.13
says:
says:
Add Comment
