Automatic Melon Farm in Minecraft
4,039
Published
Introduction: Automatic Melon Farm in Minecraft
right. you've got your invincible fort and all your items are safe. but raiders have destroyed your farm!
Luckily I have an answer for that! (what would you do without me)
Step 1:
To get your melon just do this. get some grass and place it like in the picture with some water next to it.
Step 2:
then add a redstone block/redstone torch (anything that'll give off a redstone signal) connect a repeater to it.
Step 3:
add hoppers along the sides to collect the melon. (also make it so the repeater is on top of a hopper) and add a piston like so. make sure that the melon can only be placed on the grass block. then if you've built it correctly you'll have melon for days! Thanks for reading!
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Stick It! Contest
      Stick It! Contest
    4 Comments
    It doesn't work because a piston can't be powered from the front but it is a good idea.
    wait.. The piston isn't powered from the front. The repeater shoots a signal through a melon/pumpkin. So it should still work
    must be because of the update I haven't used this since 1.8
    unfortunately the world I usually build on is corrupted! so I'll have to make another one
