HOME I/O- Automatic Open/Close of Entrance Gate
1,884
10
Posted in TechnologyElectronics
Introduction: HOME I/O- Automatic Open/Close of Entrance Gate
About: I'm a Mechatronics Engineer & a passionate teacher. As an engineer i'm involved in Control circuit designing. flexible education training designing & research work in various elements of Automation like Ardu...
OBJECTIVE:
LATCHING THE OPEN & CLOSE OPERATION OF THE GATE
The Gate should open completely on rising edge of Sensor 1 & Gate should close completely by falling edge of Sensor 2
Control:
Connect I/O.
Download Software here
Programming Platform:
FBD (Inbuilt Connect I/O)
Environment: Home I/ODownload Software here
Starting Conditions: The Gate is Closed
I/O Signals
Inputs:
  • Entrance Gate Infrared 1
  • Entrance Gate Infrared 2
  • Entrance Gate Opened
  • Entrance Gate Closed
Output:
  • Entrance gate Close
Connect I/O Functions to be used
  • RTRIG
  • FTRIG
  • SR
  • RS
Step 1: Latching the Opening of Door Using Rising Edge of Sensor 1
We have used the rising edge of Infrared Sensor 1 to latch the output via SR Block. When Sensor sensed the object/person, it will give signal to FTRIG. FTRIG will give 1 Pulse to SR which will latch the Bit 193 & starts opening the gate even if the object in front of the Infrared Sensor 1 is removed
Step 2: Unlatching the Output Bit When Door Is Fully Opened.
Bit 260 Entrance gate Opened is used to unlatch
the Gate Open bit, when the gate is 100% opened. The signal from BIT 260 goes to Reset1 terminal of RS Block which has reset the BIT 193 i.e. opening bit of Gate
Step 3: Latching the Close Operation Using Infrared 2
Similar to Step 1, Infrared Sensor 2 (Bit 263)
is used to close the Entrance gate. Unlike the opening operation, here we have used Falling Edge of Infrared Sensor 2 because, the gate should get command to close when the object/person passed across the Infrared Sensor 2 to avoid collision if the object is in front of Infrared Sensor 2
Step 4: Unlatching the Output Bit Using Gate Closed Bit
Similar to Step 2, Entrance gate Closed Bit 261 is used to reset the Close operation of the gate.
This cycle can be repeat again & again.
Check out theVideo Demonstration
Want to learn PLC? Get E-Leanring offers at http://online.nfiautomation.org
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Cool! Thanks for sharing and welcome the the community!
