3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Automatic Pool Water Filler
This device will automatically add water to your pool when it gets below a specified level. It does this all for under $15. By having a device fill the pool to a specific level, you can avoid wasting water by overfilling.
Step 1UPDATE: VERSION 2.1 Cross Section Added For Stability
After version 1.0 kept falling over in the water, I added a cross section for stability. I spray painted the PVC Black to help protect it from the sun. It also makes it look much more finished.
73 comments
1-40 of 73next »
Mar 14, 2011. 4:37 PMjzimmer says:
Awsome just made mine
May 21, 2012. 4:46 PMjsbfla says:
Just finished mine - works slick. My Fluidmaster float was a loose fit in a 3/4" thread-slip adapter, so I just mixed up some JB Weld, coated the inside threads with it, and it tightened up perfectly. Thanks.
Mar 14, 2011. 7:50 PMjzimmer says:
no epoxy the float i got threads fit nice to a 3/4 coupler and as you can see i its an inturnal float so i was able to put it up against the poolside for less chanses to get broke
Mar 14, 2011. 10:31 PMjzimmer says:
i got it from lowes not sure on the threads its made by korky . i just played around in the pvc area putting the whole thing together took it on pvc glued it and pressure tested it and vac tested and was hour long no air leaks
Jan 28, 2012. 9:58 PMflyznest says:
ballcock is the name assigned to the toilet valve thread.... i found a ballcock x 1/2 reducing adapter at my local ace... fits perfect on the toilet valve... for some weird reason it threads perfect to a 1/2" threaded pvc coupler, but not to any other fitting. i had half the staff at ace stumped on that one. but it works!!! thanx for the design! its brilliant!
Jun 4, 2011. 11:24 AMjongscx says:
Oh my god... this is amazing.
How long does this take to fill a pool? I'm assuming the flow rate is much less than just an open hose.
May 5, 2011. 9:16 PMFreyberger says:
Great idea. I have made one for an above ground pool and it works like a charm!!
Mar 24, 2011. 11:14 AMhdhilli says:
I just finished my version which works just great. I used a slip/threaded PVC fitting between the elbow and toilet fixture. This saved me because I used too much epoxy and has to drill out the opening. Replacement of the fixture will also be easier...just epoxy a new one on a new fitting and screw it into the existing assembly.
Mar 16, 2011. 7:05 PMZipdaddy says:
Wow...This falls under the "Why didn't I think of that?" category for a lot of us!! I'll be making one for sure. FYI HINT....Use electrical PVC....It's UV resistant.
Aug 15, 2010. 5:26 AMincognito53 says:
I've thought about doing something similar to this for a while.. How bad of an idea would it be to tap the suction pipe going into the pump and connect thru a valve to the water supply? Reason why is, I really don't want any extra pipes going to the side of the pool
Aug 7, 2010. 4:45 AMsteveo625c6 says:
I am truly surprised this hasn't been thought of till now, I mean if something as simple as a toilet has an auto fill, why can't your personal pool have one? Haha...Great instructable man!
Jul 26, 2010. 2:13 PMMudbud says:
what if people were splashing and jumping into the pool? it would make the water level unstable therefore turning the thing on and off for filling. Im not trying to be rude im just thinking about it before I make one.
Jul 22, 2010. 12:30 PMKJenkinsAF says:
Dude, I'm rushing out to the plumbing store to do this RIGHT NOW...GREAT idea.
Jul 8, 2010. 4:40 PMMy name is not Steve says:
I think the answer is a different float valve. I just found this online today. http://www.hudsonvalve.com/products.html It should make the entire assembly much smaller too.
Jul 13, 2010. 2:14 PMMy name is not Steve says:
I found a good price. $23 for high temp. plus $5 shipping. http://www.usplastic.com/catalog/item.aspx?itemid=23234&catid=569
Jul 5, 2010. 6:45 PMMy name is not Steve says:
Hello gents. This is similar to the idea I've been planning. My idea is essentially the same but offers the toilet filler protection. Encase the unit in a pvc pipe wide enough to contain the toilet filler. Use an end cap and drill a hole in the cap for the filler. Mount the filler just as you would in a toilet tank. Drill another hole or two in the cap (pipe too?) so water can get in. In my pool there is a small diameter pvc pipe near the surface and connected underground to to a house spigot. I'll get the appropriate connectors for that and figure out another way to to secure the unit. I'll probably just use an elbow on top and another length of wide pvc filled with a bag of rocks much like the store bought units. I'll put "feet" on it to keep it from rolling.
Jul 6, 2010. 5:37 PMMy name is not Steve says:
Regarding your need for a mount without epoxy, how about a second hose coupler for a 3/4 inch hose. Use as short a piece of hose as you need to fit it over the threads of the filler (not positive it will fit) and hose clamp it. The short piece should be rigid enough so the filler will still stand upright. I found a store in NV that makes custom hoses. The plumbing supply store just told me about them. Alas, there are no 7/8 brass fittings anywhere. :(
Jul 6, 2010. 2:09 AMMy name is not Steve says:
I just read that copper pipe is not good in swimming pools, but how about this? Use a short piece of copper pipe and appropriate fitting for the filler and a copper to pvc coupler on the other end. Could this assembly be painted or coated with something to protect it from the pool water? Just brain storming here. :-) I don't know if there's a copper fitting for the filler base.
Jul 6, 2010. 11:45 AMfreakyqwerty says:
Doesn't a toilet have the same sorta system?
Mar 24, 2009. 11:43 AMdchall8 says:
This is really a good idea. Why do you epoxy the valve on instead of threading it on?
If you do not have a PVC pipe cutter, GET ONE. It cuts through pipe like a hot knife through butter. You only have to use it once to realize a hacksaw is a dangerous waste of time.
Jun 29, 2010. 1:33 PMdarthstupie says:
Why not use a supply line that is made to connect to these valves and the PVC pipe. It wouldn't be as ridged but another mount could be made to hold the valve. Just a thought.
Jun 30, 2010. 9:30 PMdarthstupie says:
You should be able to use a toilet supply line (they are flexible, not rigid like PVC) available at most any home improvement store. They usually have to connect to another valve to cut water off to the toilet in order to make repairs such as replacing the automatic valve used in your instruclable. As for a fitting only, I do not know. I will ask one of the guys that work in the plumbing dept of the store where I work. Great instructable by the way.
Jul 1, 2010. 10:30 PMdarthstupie says:
You are correct that the fitting does not exist. I checked with The sales specialist in plumbing where I work and it is not even something that could be ordered. Good luck with the re-design btw.
Jun 30, 2010. 12:22 PMmattbomb says:
so your basically making a big toilet right. lol great build man well built
Jun 30, 2010. 12:13 PMSinAmos says:
It just reminds me of how wasteful pools are when it comes to water usage.
1-40 of 73next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:whosdadog
