Automatic Prank
Published
Introduction: Automatic Prank
About: Want to do some thing best with my less resource.
While some one open the door and get in. Is any thing fall in their head they think its lizard or spider and get prank. But at each time we want to place it over the door and get back is not a good idea. So automatically if the spider goes up and down then it is very fine. Come lets see how to do.
Step 1: ‚ÄčMaterials Needed
Materials Needed
1) jump clip 2 nos or Anchor bolt.
2) Paper Tape (if use anchor bolt then hammer to fix it)
3) Thread.
4) Item to prank (I use a doll key chain, Try with rubber spider or lizard or snake).
5) Counter weight. I use a bottle filled with water).
Step 2: Plan
Plan for the automatic prank is given above. when the door opens the counter weight pull up and the prank item get down. When the door close the counter weight pull the prank item up. Come lets see how i did it.
Step 3: Prepare the Jump Clip
1) straighten the small side of the jump clip.
2) Make a 2 small round in the straighten side.
3) Make two jump clip like this.
Step 4: Fix the Jump Clip
1) This is my room Door. Fix the Jump clip on the wall above the door using paper tape. Fix it nearly half feet up from the door. Then only the prank item never stuck in the door while closing.
2) I never fix the jump clip in the center of the door. Because my door is only able to open partially. So any one only able to enter near left side so i consider the space as middle.
3) Paste another jump clip straight to the door clamp side.
4) If u have anchor then fix it in spite of jump clip.
Step 5: Connect the Thread
1) Take two long thread and insert it straight through both jump clip.
2) Tie both the thread in the counter weight bottle to the door clamp side .
3) Leave the bottle to hang and hold the other side of the thread.
4) Split the threads on the opposite side and paste one thread to the corner of the door.
5) Close the door and now the thread is tension because of the counter weight.
6) Take another thread and tie the doll or rubber spider or snake or lizard or any other item in the thread some space above the door (this only avoid item from stuck in side the door)
7) If low weight item is used add some item for weight with the item(i add a small weight over the item).
Step 6: See the Finished Work
See the full Construction.
Step 7: How It Prank
Place a camera on facing the door and record how others react. When the door open and got in it stuck their head.
Step 8: Watch How It Works
Have fun.
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    2 Comments
    Quite a few years ago where I was working we had a guy who was 6'7", built like a brick outhouse and absolutely terrified of spiders. We were in an open-plan office and his phone was on top of a filing cabinet between two desks. So, one day, someone tied a piece of black cotton to the phone handset, and the other end to a fake spider, hiding it down the back of the cabinet.
    The suspense, waiting for the phone to ring, was unbearable. Eventually it did, he picked up the handset, saw the attached spider appearing from the back of the cabinet and screamed, hurling the phone across the office.
    Luckily, he never did find out who did it.
