Automatic Temperature Controller for FishBowl (Controlador Automatico De Temperatura Para Pecera)
747
15
Posted in TechnologyElectronics
Introduction: Automatic Temperature Controller for FishBowl (Controlador Automatico De Temperatura Para Pecera)
About: I love to do electronics projects, and also to share them
ENGLISH
In this little instructable I will explain how to wire a W1209 temperature controller , and also wire some led light strips , this is my second instructable so I will try to make it better as possible .
ESPAÑOL
[En este instructable voy a explicar como conectar el modulo controlador de temperatura W1209 , y tambien conectare unas tiras de led , este es mi segundo instructable , por lo que tratare de hacerlo lo mejor posible.]
Step 1: Materials
ENGLISH
For this project you will need :
1) A W1209 Temperature Controller with sensor (The main piece in this project ,I had bought this in my local hardware store , but you could buy it online )
2) A led strip (Aproximately the lenght of the fishbowl you will take as reference )
3) 3 Different colour led (Will serve as indicators)
4) 1 Project Box (I will recycle one that had for other project and never was used , it was a 6v sealed battery container with 2 switch , 1 volt meter, 2 screw terminals )
5) 2 Resistor of 1 k (The W1209 module uses 12v that i will need 1 k ohm resistor)
6) 1 12v AC Adapter (Will act as a power supply for the project )
7) 2 Mounting screws (I used 2 with screw and nut )
8) Wire (Approximately 1 meter)
ESPAÑOL
[ Para este proyecto necesitaremos :
1)Un modulo controlador de temperatura W1209 con sensor (Es la parte principal de este proyecto , Este lo tuve que comprar en una tienda de electronicos local , pero lo puedes comprar en internet)
2) Una tira de led (Aproximadamente la longitud de la pecera como referencia)
3) 3 led de diferente color (Nos serviran de indicadores )
4) 1 Gabinete de proyectos (Voy a recicclar uno que tenia para otro proyecto y nunca fue usado , era un contenedor para una bateria sellada de 6 volts con 2 interruptores , 1 voltimetro y 2 terminales de borne)
5) 2 Resistencias de 1 k ohm (El modulo W1209 usa 12 voltios asi que se necesita este valor )
6) Un adaptador Ac a dc de 12 voltios (Va a ser nuestra fuente de alimentacion para el proyecto )
7) 2 tornillos para el montaje del modulo (Yo use 2 tornillos y 2 tuercas )
8) Cable (Aproximadamente 1 metro)
Step 2: Tools
ENGLISH
Are the most common used :
1) Soldering Iron
2) Soldering
3) Cutting Pliers
4) Screwdriver
5) Insolating Tape
6) Drill (I have one but i dont have the apropiate drilling bit , that I used a screw with a pliers , then I heated it and did the drilling by pushing to the plastic)
ESPAÑOL
Son las mas comunes y usadas
1) Cautin tipo lapiz
2) Soldadura
3) Pinzas de corte
4)Destornilladores
5)Cinta aislante
6)Taladro(Tengo uno , pero no tengo la broca apropiada , asi que use un tornillo con pinzas , despues lo calente y perfore el plastico del gabinete.)
Step 3: Prepare the Project Box
ENGLISH
As I had said before , this project box was used to put a battery , for that case I will need to cut every wire inside and making the mounting holes for the module, I could install everything inside , and only the display and buttons outside , but it means to disolder most of the parts of the module and it could end in damaging the pcb so I did put the module outside.
Other thing that I have done is to remove the small led and replaced with other led installed in the project box
ESPAÑOL
Como lo dije antes , este gabinete de proyecto fue usada para una bateria , para este caso voy a necesitar cortar cada cable dentro y tambien hacer las perforaciones para montar el modulo , podria haber instalado el modulo adentro , lo que implicaria desoldar la mayoria de los componentes , para dejar unicamente los botones y el display afuera ,pero no lo hice por que podria terminar en dañar la pcb asi que puse el modulo afuera
Step 4: Wire All the Project
ENGLISH
Once that I have installed the temperature controller I started the wiring everything in the box , theres a schematic for reference.
ESPAÑOL
Una vez que ya se haya instalado el controlador de temperatura , comence por cablear todo dentro del gabinete de proyectos , hay un esquema de referencia .
Step 5: Finish the Project
ENGLISH
As the title says this is the last step in this instructable , Only i had to plug the power , the sensor wire and the led strip wire.
Once that the temperature control module has been powered you have to program it , in one picture you can find how to program it.
In the pictures are more detailed information about the parts and project working .
If you have any question or comment about this instructable , please feel free to write it , Thanks for reading this instructable
ESPAÑOL
Como el titulo dice , este es el ultimo paso en este instructable , Solo conecte el adaptador , el cable del sensor y la tira de led , Una vez que el controlador de temperatura ha sido encendido , hay que programarlo , en una imagen puedes encontrar como .
En las imagenes hay mas detallada informacion acerca de las partes y el proyecto funcionando .
Si tienes alguna pregunta o comentario acerca de este instructable , por favor comentalo , Gracias por leer este instructable
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    Im trying to improve my english so im not so good at , but Thanks , I will take as a recomendation for my next instructable.
