Automatic Water-Tank Motor Controller
Introduction: Automatic Water-Tank Motor Controller
You can see the working of this controller explained in the lovely diagram...
Its a simple controller, which would help to turn the water pump on, when your water tank is empty, and will turn it off when the tank gets full, and will keep it turned off until the tank is empty...
Step 1: Working
The lower sensors acts as the 'J' input and the upper sensor acts as the 'K' input in the J-K flipflop...
the working of both the sensors is opposite, i.e. the upper sensor gives output 1 when the water is detected, and the lower sensor gives output 0 when the water is detected...
With this kinda sensing, we can predict the JK flipflop's output as-
when there is water on both sensors, input = 0 1, output = 0 = motor off
when water is coming down after filling up, input = 0 0, output = 0 = motor off
when water comes below the lower sensor, input = 1 0, output = 1 = motor on
when water starts rising from the lower sensor, input = 0 0, output = 1 = motor on
Step 2: The Circuit
The circuit works on 12v dc power supply, which you can give from a 12v DC adapter...
The circuit is built around 3 main ICs-
LM358 - dual comparator - sensing IC
NE555 - timer ic - clock pulse generator
7473 - JK flipflop - the controller/brain
You can see the components and the connections as per given in the circuit...
The components you will need to build this circuit are -
-12v dc jack female
-1x(100uf or 200uf or 500uf or 1000uf) + 1x10uf capacitor
-7805 volt regulator + heat sink
-2x 500k potentiometer
-2x 47k ohm resistor + 2x 470 ohm resistor +1x 330 ohm + 1x 270 ohm + 1x 100ohm + 2x 10k ohm resistor
-LM358 IC + base
-LM555 IC+base
-7473 IC + base
-1x diode
-12v relay = heavy duty according to motor
-2x red led + 1x green led + 1x yellow led
-1x BC547 transistor
-12cmx12cm prefboard
-12v DC adopter
correction - the pin 2 and 6 are connected in the 555 IC in the circuit.
also do connect the Vcc and Ground of all the ICs, you will easily get the pin configuration of the ICs on google...
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    I also want to add a float sensor for underground tank, because if water is not available in underground tank then our motor will be damaged.
    Please tell a solution for it.
    here is the solution, you can add an AND gate and an extra water level sensor module to implement that functionality....
    Thanks for responding.
    Bro did u have any innovative ideas
    Yes, bipods, hexapods, etc
    its grate job very usefull for biginers
    I am planning to try this circuit and wanted to know what kind of sensor need to be used with this circuit?
    I want to try this..but may I know what LED do when running sir..? do they flip-flop when relay start pump "On" or else..coz i'm beginner here..thanx for information:-)
    nice circuit.
    i need little help. actually we have utilitiy water supply problem in my area. there is no timing of water supply. so i want a circuit to start my pump after every 30 minutes if water comes the motor continue to run if water not come motor stop after 1 or 2 minute. any body plz help me
