Introduction: Automatic Street Light
Picture of Automatic Street Light
Automatic Street light turns on whenever there is insufficient light intensity & automatically turns OFF when there is enough light.
Step 1: Parts
Picture of Parts
You need 4 parts as listed below:-
1) Transistor 2N2222 ( A basic switching transistor)
2) 220 K LDR (Light Dependent Resistor)
3) Resistors 1.5k ohm & 220k ohm.
4) LED
Apart from this You need a GCB & a battery cap.
You can Buy these Parts from HERE !
Step 2: Circuit Diagram
Picture of Circuit Diagram
Step 3: Working
The transistor 2N2222 is used here as switch. The transistor is voltage divider biased.
  • When the intensity of light is enough the resistance of the photoresistor is low therefor the current gets bypassed instead of going into the base of the transistor. Therefore the transistor turns OFF.
  • When the intensity is less the resistance of the photoresistor is high & so current starts flowing through the base & the transistor turns ON.
Step 4: Applications
Picture of Applications
The main aim behind making an automatic street light is to save the power. As the light turns ON & OFF according to the requirement it saves the power & also decreases our work.
About This Instructable
3,776views
46favorites
License:
More by Darp Raithatha:Home Automation & Control Systems Home Control SystemSmart Remote controlled lights
Add instructable to:
