3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Automatic system to separate trash
At the present time, the ecological balance has been altered by the increase volume of sweepings that is created day to day, thus it is of great importance of finding efficient solutions that allow us to introduce to the new generations in systems in favor of the ecology as in recycling. It is for this that a capable mechatronic system was created to detect the physical characteristics of the residues and to separate it depending of the material of which this is formed, with the purpose of transporting this separated sweepings to the diverse methods of recycling. This system give us the possibility to increasing in great percentage the volume of recycled sweepings saving energy to create new raw material, smaller contamination and a clear diminution of possible diseases in the places near the dust-bins, mainly in cities where it is not counted on the facilities adapted for the treatment of these residues. The application of this type of systems can be from home, public areas or industrial volumes, everything under the same functional principle. In order to obtain the detection of the material we used the most common electricity principle, the capacitance. As we know all material has a dielectric constant, which is the property that makes difficult the conduction of tension, considering the emptiness like a value of equal capacitance to zero. Using this physical principle, we will use a capacitance sensor type, which grants a digital sign to us when detecting an object with a greater dielectric value to the one of the air. On the other hand the detection of the object side affected by the parallel distance to the sensor and the dielectric value of the object. This allows us to use this principle with our system, since if we know the distance to which the sensor detects our object we will be able to know the value dielectric of the material. Finally we know that the area of the object of parallel form to the sensor also influences in the detection range of the object, is by which was necessary to place an area sensor to detect the size of the object, with which we will obtain two variables; on one hand we have the object area and by the other side we have the distance to which the material was detected. These two variables will be placed in a simple graph where x-axis will be formed by the area of the object whereas the axis and will be formed by the detection range. In clear and constant form each material forms a rank of the value of the slope with which we can identify the material perfectly. The efficiency obtained by the system is around 90% with consumption no greater to 300 watts by classification, and 10 watts in rest and if we considered that the prototype had a cost of around 300 dollars and the manufacture is very simple, therefore the system becomes a very interesting option to solve the problem.
If you want to see all the information, yo need to see this web:
http://www.createthefuturecontest.com/pages/view/entriesdetail.html?entryID=1858
thanks
Step 1Automatic system to separate Trash
1 comment
Sep 5, 2008. 11:02 AMadmin says:
Hello, and welcome to the Instructables community! It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable. Successful projects on Instructables include: - clearly written details of a finished project with instruction - as many steps as are necessary to explain your project - clear images that you took of your project for most, if not all of your steps - an intro image - proper spelling and grammar - appropriate cautions or safety considerations I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note. Thanks for your submission and we hope to see your project published soon!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:brnaer
