This Instructable will show you how to be green without so much work on the going part. You will be presented with several easy ways to conserve energy by reducing the energy used by lighting and controlling the climate of your home, and in the process, save money, all automatically. When it comes to going green, less work is sometimes better. Automation is the key.
The steps in this Instructable contain comprehensive (and a bit expansive) background information and statistics which describe the usefulness of each method to be Automatically Green. This information is also meant to illustrate the economical and environmental advantages of these methods. If this information does not interest you, skip to the last step for the instructions without so much information.
Remove these ads by
Signing UpStep 1Change The Lights
About 12% of the annual energy budget for the average American home is used for lighting. This equates to about 1200 kWh/year per home or about $128, just to run the lights. What is more appalling, however, is that 90% of this energy is emitted as heat instead of light. Not only does this cost the average U.S. home about $115 each year, but it also contributes heat to the house in the summer, raising air conditioning costs.
The Solution:
We have all heard it a million times, but replacing incandescent light bulbs with compact florescent ones is an essential step in improving your home's efficiency. No energy saving habits or switching gadgets can replace the vast improvement in efficiency between incandescent and compact florescent bulbs. Compact florescent light bulbs use 75% less energy than incandescent bulbs to produce the same amount of light. Lastly, while compact florescent light bulbs are significantly more expensive than incandescent bulbs, the energy they save more than compensates for this difference. An Energy Star compact florescent light bulb saves about $30 over its lifetime and it also helps to reduce electricity use and greenhouse gas emission. If you want to know how much money you can save by replacing your conventional light bulbs with compact florescent, take a look at this calculator developed by the Environmental Protection Agency and the U.S. Department of Energy: Savings Calculator. Yet another way you can save by switching to compact florescent light bulbs is through special rebates which may be available in your area; visit this website to find special deals where you live: Rebates
L
L
