3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Automotive electronic flasher rate modification.
For anyone who has added LED bulbs to their vehicles turn signals or brake lights.
Since the LED bulbs use less Amps than normal bulbs, the flasher unit thinks there is a bulb burnt out and doubles the flash rate. This instructable will show you how to alter the flasher module in your car for variable flash speeds.
Note: This is for electronic relay type flashers only. This will not work on thermal flashers.
Step 1The flasher.
The flasher.
Here is the flasher I modified. Since I am using the flasher in my car, I just pulled this one out of another '97 Cougar at the junkyard.
There are two tabs holding the circuit board in, just pry them loose with a small screwdriver.
37 comments
Mar 14, 2012. 8:14 AMfrawtan says:
Hello! michaelsteinbach
This is a nice instructable!..^^
I just wanna ask i have 3 pin flasher for LED which i bought from ebay I also replace my 4 halogen signal light bulb 10W each to LED and now my problem is when I signal to left or right the 4 LED'S lights up together. What's wrong?..Can you help me?..please..
Thank you very much...
Dec 19, 2011. 5:36 PMemmarvee says:
Good one ! I drilled a couple of small holes in the top of the unit and installed a trimpot, and glued it to the top. Works a treat. Cheers.
Dec 19, 2011. 7:10 PMemmarvee says:
'Tis one of the bummers of the modern car. Would cost you a fortune to be able to programme these things. I am still driving a 1998 TD Isuzu twin cab, so don't have these problems. Will have to come into this century in a few years I suspect.....
Mar 19, 2011. 4:38 PMdjrey says:
Thanks..... It work perfect in an OPTRA chevrolet... I buyed the 500k knob potentiometer and added a 2' long cable and installed in my dash.. to give it a strobe effect once in a while...
I calculated that in my car it was needed about 250k resistance to make it flash "normally"
Nov 29, 2010. 8:36 PMFoxtrot70 says:
I have a 2000 Dodge 3500 4x4 diesel and I replaced my tail lights with LED types and of course because of the lighter load on the circuit it would flash rapidly. I went in and found the resistor on pins 4&5 and lifted one leg and then installed a PC mount mini 100k variable from Radio Shack p/n 271-284 cost $1.49 and tuned in the desired slower flash rate. In some cases you might need to replace the original resistor with a 200k and then add the 100k variable and then adjust, On my flasher the electrolytic cap is a 3.3uf as opposed the the 4.7uf in the schematics. Easy mod if you know how to solder, use a magnifier and have a steady hand.
Nov 5, 2010. 9:27 PMzack247 says:
really? car flasher "relays" (not sure if it called a relay) have IC's in them? i didn't know that...
May 17, 2010. 5:45 AMjoelewinski says:
OOPS!  You've highlighted the CAPACITOR, but the note says RESISTOR.  It's probably clear enough for most of us, but it COULD confuse the noobies!
Just sayin'…
Joe L
P.S. - Great "ible", I'll be doing this soon!
Apr 8, 2009. 3:39 PMgeekchic says:
Could you just use the equation for the frequency on page 4 of the datasheet for the IC and the value of the capacitor to determine what resistance you'll need for a given flash frequency? Or is that not going to work since the load of the indicator lamps is different?
Or, could you at least use that formula to determine what the initial flashing frequency was?
Either way, I'd still do it your way, using a potentiometer, because you can set it exactly how you like it.
May 7, 2009. 4:18 PMchevyhector says:
What would be needed to make the tail/turn signals sequential? I would like to add a 3 stage turn signal for each cycle.
Nov 4, 2008. 8:56 PMFast Eddie says:
Maybe a dumb question, but could you simply wire the variable resistor between the Light-out of the unit and the wire going to the bulb?
Sep 24, 2007. 8:23 AMMr. Rig It says:
Excellent, I need to build an entire turn signal flashing unit for my atv. I can use this. Would you happen to have the schematics for such a unit? Good ible
Sep 24, 2007. 4:45 PMjongscx says:
are your re-building one from scratch or are you building a new one without a pre-existing signal? I'm just saying because if it's to replace the light-bulb with LEDs, but you have the signalling wiring in place, then this would work. If you're adding a turn signal to an ATV without one, then it would probably be better to use purpose-built components (I'm thinking a 555 based blinker would be simplest) than adapting car components to fit LEDs to fit IN an ATV
Sep 24, 2007. 4:57 PMMr. Rig It says:
It would be one from scratch. If it gets really complilcated then I think I will shy away from building one. But if it straight forward I could probably do it. I just need a simple plan.
Aug 27, 2008. 4:51 PMstuuf says:
I know this is an old thread, but I recently built a new flasher from scratch for my Accord to use with LED turn signals. It doesn't have any current sensing/hyperflash mode like normal flashers, just a 555 oscillator driving a relay. And a speed control dial so I can turn the blink speed back and forth to make other drivers think they're going crazy... I'm working on an instructable for it.
Sep 25, 2007. 1:29 PMkillerjackalope says:
dude if there's no real worry about flash speed (FLED aren't far of anyway) use a set of flashing LEDs these are LEDs with a tiny flash circuit inside then you switch them on like normal so make a grid of flash LEDs for the light shape hook up to a DPDT switch or possibly a triple throw trpile pole... simple stuff basically same switch but no complicated blink mechanisms or circuits.
Apr 2, 2009. 12:55 PM12V says:
after a few seconds you may find that they turn on and off at different times!
Apr 3, 2009. 11:47 AMkillerjackalope says:
Ah, I didn't think as far as the circuits getting out of line...
Sep 25, 2007. 2:33 PMMr. Rig It says:
That is a good idea. I will keep it in mind. Thank you
Sep 24, 2007. 5:04 PMjongscx says:
My suggestion would be to find something made for a bicycle or a scooter. They have "urbanizing" or "commuterizing" kits (don't quote me on those terms) but basically they're so that you can make your bicycle road-safe/ready. They're pretty light and rugged, and very simple, so they're usually cheap.
The hardest part of the(your) build IMO would be the user-interface, as in how you'd mount it and use it while riding.
http://www.bikeworldusa.us/Acclaim-Turn-Signal-Directional-Brake-Light/M/B000SMCY0E.htm
is a comercial fitting for a bike, so if you find something like that, you could use the circuitry for controls and just scale it up with relays to get brighter lights.
Sep 24, 2007. 5:36 PMMr. Rig It says:
I have one very simular to that one that I was going to use just for that. However it is only for the rear of the ATV. I woul dhave to run some wires to the front also. I just don't know how much power it would require to do it. I would also want to wire it into the power system of the ATV instead of using AA batteries. I have the turn siganl switch that cam with it, it is thumb atctivated just like a motorcycle. It's perfect, like I said I was going to use it but I am unsure of the wireing and the power draw. Oh it also has LED lights. It has a brake light and turn flashers. I'm just LED ignorant. Any ideas?
Sep 24, 2007. 6:01 PMjongscx says:
Your ATV is probably running on 12V... anything with LEDs has a low power requirement, probably between 3-6 V (2 or 4 AA batteries at 1.5V each) Now, it IS possible to hook it up to the 12V, but you'd need some kind of regulator. One possibility is to find a car cell-phone charger with similar voltage and hook it up like that. easiest way to find the voltage, multiply the number of batteries by 1.5... HOWEVER, you should also look out for wattage. I'm not too knowledgeable on that, so we should wait until somebody else comes by. As for running the wire, I'm not really sure. You could just stuff it in the seams of the paneling I guess, under the seat, in the weatherstripping? I do advise that you hide it and attach it to something so it's not just hanging there.
Sep 24, 2007. 10:17 PMMr. Rig It says:
My ATV is a 12 volt with a 500 watt magneto so power isn't a problem. The cell phone charger is a good idea, which I can do and most likely will do. I can run the wire, that isn’t an issue either. I think the hardest part is looking at someone else’s project and trying to figure out all the little electrodes and such and then add on to it. Isn’t that the most fun part though? I think so, because every time I do I learn something new. I just don’t have experience at circuit boards and smaller electrical parts. I have basic knowledge of LED’s and I know what a resistor is. But when it comes to capacitors and all the others that’s when I get in trouble. I wonder if this should be a collaboration project. I could post pictures of my LED turn signal disassembled and other people could weigh in with their thoughts.
Sep 25, 2007. 6:49 AMchavez00001 says:
this is a more correct schematic than the one you made.
Sep 24, 2007. 8:05 AMjongscx says:
...could you set it up to blink in accord to the music you're playing on your stereo?
Sep 24, 2007. 4:41 PMjongscx says:
So I guess my idea of a disco-car, with strobe-light headlights and disco-ball rims would be out too...
Sep 24, 2007. 3:32 AMPatrick Pending says:
Nice bit of hardware hacking. You can, of course, replace the variable resistor with an equivalent fixed resistor once you have determined the correct flash rate. Cheers, Pat. Pending
Sep 24, 2007. 10:04 AMLasVegas says:
You mentioned having found the schematic to your flasher unit. Could you add that to the photos? Also one can easily find relay type flashers to replace older style thermal flashers. They probably have very similar circuitry.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:michaelsteinbach
