Remove these ads by
Signing UpStep 1
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
This means that the centre of the tread wears more quickly and you will need to replace tires more often - it's a trade-off - fuel or tires.
Also, if you want to see something even more interesting using water check out the 6-stroke diesel http://en.wikipedia.org/wiki/Crower_six_stroke. Absolutely brilliant.
ingelasuya.
:D
after a little research I found that thats why they only use 2 to 3 ounces to a gallon of gas or diesel fuel,
if you only use a small amount of acetone you shouldn't have to worry about it eating away on your fuel lines
this, like any other Instructable is for you to do at your own risk, so if you don't like the idea, or think it's dangerous DON'T DO IT, it's as simple as that
we also drive a diesel car,a 2006 VW Transporter
If it melts your plastic jug, it's going to melt the gaskets in your engine, your fuel lines, and your fuel injectors also.(which are sealed against the engine with cute little plastic boots).
http://en.wikipedia.org/wiki/Methanol_fuel#In_practice
http://en.wikipedia.org/wiki/MythBusters_(season_3)
