3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Autonomous, Self-Assembling Robots
Step 2Electronics overview
electronics overview
We designed the electronics to be simple and flexible, because we had not finalized the robot design when we started and planned to try a variety of control algorithms, actuators, and communications methods. We also needed the electronics to be small and light. We decided to go with fairly small SMT parts for the final design, and were able to get a microcontroller, 10 status LED's, 4 FET's for driving actuators, and the programming/power header onto the 25mm x 25mm board, plus connection points for 4 actuators and 4 sensors. We tried making the board even smaller, but it became too hard to assemble. Our strategy for simple and flexible worked out - we've since used leftover boards for 3 other, totally unrelated projects.
3 comments
Jan 11, 2011. 1:00 PMCeaton99 says:
Is there any way to make these like cubes
Apr 17, 2008. 1:57 PMDeusExMach says:
at first, I was going to point out that your microcontroller isn't lined up, polarity-wise (the notched corner usually matches the part marking on the pcb/pwb/wtf-ever) Then I noticed ALL the corners are notched. Did you use the writing on the MC to orient your polarity, or does it not matter?
Sep 19, 2009. 3:14 PMJermsG says:
I could be mistaken, but it looks like there's a small circular indent in the top left of the m/c, sorta hiding under that wire. Yes it would definitely matter, so if I'm wrong and there's no indent, they must have used the writing to orient it as you suggest.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
524
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
