Autonomous Irrigation System
332
5
8
Posted in TechnologyArduino
Introduction: Autonomous Irrigation System
About: Innovation is my Oxygen.
This is an Autonomous Irrigation System which has the capability to detect the soil's moisture and keep the plant hydrated.
*This is my first instructable.
Things required:
*DC 3 V-6 V Micro Submersible Mini Water Pump.
*Aquarium Flexible Silicone Air Tube.
*Breadboard.
*Arduino UNO.
*Relay Module With Optocoupler.
*Soil moisture sensor.
*Jumper Wires
So,let's get making!
Step 1: Making Connections.................
*Connect the Moisture Sensor to Pin 2.
*Connect the Relay module to Pin 3.
*Connect the Green Led to pin 4.
*Connect the Red Led to pin 5.
Step 2: Let's Get Coding..........
/***************************************************************************** AUTOMATIC IRRIGATION SYSTEM***************************************************************************/
  int SENSOR=2;//Moisture sensor is connected to Pin 2.
int RELAY=3;//Relay is connected to Pin 3.
  int LED1=4;//Green LED is connected to Pin 4.
 int LED2=5;//Red LED is connected to Pin 5.
int VAL=0;//Will be used to store the value of the sensor.
 void setup(){   //Configuring the pins as INPUT and OUTPUT.
 pinMode(LED1,OUTPUT);//Set the Green LED as OUTPUT.
  pinMode(LED2,OUTPUT);//Set the Red LED as OUTPUT.
 pinMode(RELAY,OUTPUT);//Set the Relay Module as OUTPUT.
pinMode(SENSOR,INPUT);//Set the Moisture Sensor as INPUT.
 Serial.begin(9600);//Start the communication at 9600 baud.  }
 void loop(){   VAL=digitalRead(SENSOR);//Fetch the INPUT from the Moisture Sensor and store it.
 Serial.println(VAL);//Print the INPUT gathered from the Moisture Sensor.
 //Check whether the INPUT  is HIGH or LOW.
  if(VAL==LOW){     digitalWrite(LED2,HIGH);//Turn on the Red LED.
  digitalWrite(LED1,LOW);//Turn off the Green LED.
  digitalWrite(RELAY,HIGH)//Turn on the PUMP.
  Serial.println("DONE!!!!!!!")//Print the quoted text.
 delay(10000);//Stop the pump for 10 Seconds.   }else{
  digitalWrite(LED2,LOW);//Turn off the Red LED.
 digitalWrite(LED1,HIGH);//Turn on the Green LED.
   digitalWrite(RELAY,LOW)//Turn off the PUMP.
   Serial.println("WATERING!!!!!!!")//Print the quoted text.
delay(10000);//Delay between reads.
*Please Note:If the code doesn't work then please feel free to comment.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    8 Comments
    I am from Jharkhand ,India.
    To be more precise from Bokaro Steel City.
    Where do you come from?
    hey i don't have a youtube channel so I have uploaded some photos
    I hope it helps
    Hi I have uploaded the photo
    I hope you will like it.
    And there are a few changes in the code
    VAL==HIGH
    Is now,
    VAL==LOW
    I will be making it by 20 th
    Once it is done I will surely post the pictures.
    If you have any problem you can post it in the comment section .
    I will surely look into it.
    Happy coding..☺️☺️☺️
    VAL==HIGH
    Is now,
    VAL==LOW
