3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Autonomous Paintball Sentry Gun
Make your own, custom AUTONOMOUS SENTRY GUN!
A Microcontroller Contest Finalist and Runner Up Winner.
This instructable is out-of-date. For the most recent version of the tutorial, see the website . Cheers!
This sentry gun autonomously tracks, aims, and shoots at targets, using:
-An airsoft or paintball gun
-A webcam to find targets
-A computer to process the video feed and aim the gun
-Servo motors to physically aim the gun and squeeze the trigger
-A sturdy tripod base
-A microcontroller to interface between the computer and the servo motors
-Lots of camo paint
The end result is a paintball/airsoft spewing robot, that can turn the tides of any match.
Video if it in action here .
Want to build your own?
You're in luck! All the help and information you will need is here, and the software is free and open-source. Lots of people have already used this system in their own sentry guns, with successful results.
So go ahead, make your own, and soon your own backyard will be no-man's land, too!
P.S. take pictures during the project, and when you are finished, send me a picture, and a description of your project, and I will feature it on the Successful Projects page of my website. Thanks!
Step 1Parts List
Parts List
          Airsoft / paintball gun, or other 'projectile dispenser'
$30   Webcam
$25   Arduino (or equivalent)
$27   3 Servo motors (pan, tilt, trigger) $9 ea.
$10   Assorted screws, nuts and bolts
$9     Wood/metal for construction
$5     USB A to B cable
$2     Some 22 gauge solid wire
$2     Servo battery box
$110 TOTAL
Also, you will need a laptop or computer to run the sentry gun program. $250 for a cheap netbook, if you don't have anything else...
92 comments
1-40 of 92next »
Apr 27, 2012. 6:39 PMledfreak01 says:
im geting an error running procesing
"unsatisfiedlinkerror: C:\users\owener\documents\processing\libraries\jmyron\library\jmyron.dll: cant find dependent libraries "
why is this?
Apr 21, 2012. 8:20 AMlxu says:
Nice work. Very interesting project. Thanks for sharing.
Mar 22, 2012. 2:10 PMAJMansfield says:
What would be cool is if you then got an IR camera, so it can track body heat, and then some sort of marker (UV led vest? Tracking dots?) you can use to distinguish between your own team and others.
Dec 28, 2011. 3:35 PMdilbert227 says:
hi,
Is there anyway to reverse the direction of the of the servos through the code.
thanx
Dec 28, 2011. 6:07 PMdilbert227 says:
fastest reply ever thx.
Nov 24, 2011. 5:19 PMilpug says:
(millions of people chanting) VIDEO VIDEO VIDEO!
Seriously, amazing.
Nov 6, 2011. 10:04 PMMistaStokes says:
Awesome. I was also thinking about if one could modify a usb missile launcher (sold at most computer stores) to do this with an airsoft gun (paintball probably has too much kick). I can't build it because I know that it would lead to a real firearm being remote controlled, and no matter how awesome that sounds something bad would definitely happen!
Oct 18, 2011. 3:00 AMMRedu says:
This absolutely brilliant! Maybe i'll use this to get rid of the foxes in my garden! LOL j/k.
Seriously though i'm impressed :)
Sep 24, 2011. 6:22 AMLTM-Pedro says:
Hi, I'm from spain and i'll build a turret using your tutorial, but y would like to add some extras, such as a airsoft grenade launcher remotely controled, some tactical lasers and lights and other camera controled by a servo (wich is controlled by a joystick). I would want to know if i could use a joystick to control the airsft gun using your software.
Thaks and sorry for the grammar
Aug 6, 2011. 3:08 PMvruiz3 says:
i dont get it...how do you run the code.i got Hex editor
Jul 2, 2011. 7:38 PMincreadibad12k says:
Is there a way to have the computor remotely process the video feed to find targets?
Aug 5, 2011. 7:05 PMfinton says:
With permanent dye paintballs, this would be a good tool for identifying burglars! "And now on Crimewatch: has anyone recently seen a scumbag covered in fluroescent pink dye?"
May 24, 2011. 4:43 PMpuddingsgood says:
does it run on windows ce because i found a cheap small computoer thatruns cee but iam not sure
Jun 23, 2011. 11:57 AMXBLmonster says:
im in the same situation... i need a cheap laptop to run everything
Jun 24, 2011. 11:25 AMXBLmonster says:
BTW I'm kind of die-ing to get a sentry shield but it says you are out of stock.... and thats really the only way I can do the project since I'm new to all of this. When will you get more? And if you made that kit I bet you would get many buyers.
Jun 24, 2011. 7:10 AMpuddingsgood says:
Ya I found a 90$ computer it is about 7 inches long and they have one in android and windows ce
Jun 23, 2011. 1:42 PMXBLmonster says:
youre saying i can do it on my android phone perhaps?
Jun 24, 2011. 7:14 AMpuddingsgood says:
No it is a computer ordeals extrem but kind of it runs windows ce
May 19, 2011. 5:48 PMeragon69 says:
some what confused... you wanted the tigger to pin 6 AND the usb status to pin 6? is that correct, or should trigger be connected to 6 and usb to 5? or something else?
May 19, 2011. 8:05 PMeragon69 says:
Thanks for the quick reply. reading through your latest code now, the connections all seem to be different. x to pin 9, y to pin 8 ect. should i follow these instead?
May 15, 2011. 3:38 PMCian95 says:
Could somebody please make a video tutorial of the wiring of this?
Apr 13, 2011. 5:13 PMTomcat94 says:
Now, if someone could modify this to look like the sentry guns from PORTAL, and have a sound box to make the same sounds (Hearing "There you are" right before being pelted with paintballs? Awesome), that would complete my life. I'm definitely going to build this when I get the time and/or money...
May 8, 2011. 1:07 PMQBN-14 says:
Could you use an Arduino Mega?
Feb 7, 2011. 11:46 AMstarkec says:
when trying to run i keep getting this error,
processing.app.debug.RunnerException: UnsatisfiedLinkError: D:\Software\processing-1.2.1\libraries\JMyron\library\JMyron.dll: Can't find dependent libraries
at processing.app.Sketch.placeException(Sketch.java:1543)
at processing.app.debug.Runner.findException(Runner.java:582)
at processing.app.debug.Runner.reportException(Runner.java:558)
at processing.app.debug.Runner.exception(Runner.java:498)
at processing.app.debug.EventThread.exceptionEvent(EventThread.java:367)
at processing.app.debug.EventThread.handleEvent(EventThread.java:255)
at processing.app.debug.EventThread.run(EventThread.java:89)
Exception in thread "Animation Thread" java.lang.UnsatisfiedLinkError: D:\Software\processing-1.2.1\libraries\JMyron\library\JMyron.dll: Can't find dependent libraries
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1803)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1728)
at java.lang.Runtime.loadLibrary0(Runtime.java:823)
at java.lang.System.loadLibrary(System.java:1028)
at JMyron.JMyron.(JMyron.java:14)
at Turret_05_03.setup(Turret_05_03.java:142)
at processing.core.PApplet.handleDraw(Unknown Source)
at processing.core.PApplet.run(Unknown Source)
at java.lang.Thread.run(Thread.java:619)
I have installed jmyron as instructed in the file but i still get this error :(
Your help would be greatly appreciated :)
Mar 13, 2011. 8:46 PMtorivc says:
Can't wait to do your build.
However, I did the same thing and no results
can you explain a little more on your instructions:
"IMPORTANT FOR WINDOWS USERS: there is a folder called "Extra DLLs" - those are DLLs that JMyron depends on so make sure they're copied into your system's DLL search path - such as the Processing root directory, or even C:\windows\System32."
Place "Extra DLLs" to system's DLL search path" I don't understand this.
a video tutorial would be great for your instrucable
1-40 of 92next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:sentryGun53
